Heater and Blower Problems
Results 1 to 3 of 3
Thread: Heater and Blower Problems
    March 26th, 2007
    California
    30
    I can't fiqure out what is going on I've searched the board and still can't fiqure it out. My Blower is constantly on high and cannot be adjusted and my heater is blowing cold it sometimes starts working after about 20 minutes. My coolant level is OK and I replaced the thermostat and it made no difference. The testbook symbol is on, so what do you think? BTW there is no water in the footwells.
    23,529
    Re: Heater and Blower Problems
    Have you checked and/or swapped your relays?
    June 13th, 2006
    Kuala Lumpur
    1,852
    Hi
    Your description of the problem is not very clear. What do you want your system to do?? What are your settings??
    If you want heat and get it only after 20 minutes you might have a flow problem in your heater. Air might be trapped or coolant level might be low.
    You can not adjust your blower speed? Is it in manual control mode? If so then the small copper fingers at the inside of your dial might be broken off.
    Or there might be a wiring problem towards your blower motors.
    Jos
    1995 RR 4.0 SE
  1. 92 Heater Blower Issues
    By rangie1444 in forum Range Rover Classic
    Last Post: November 2nd, 2010, 09:58 AM
  2. Heater blower relay
    By rich201283 in forum Range Rover Mark II / P38
    Last Post: August 5th, 2009, 11:14 PM
  3. Heater/AC Blower Relay Problems
    By Bourbonrover in forum Range Rover Mark II / P38
    Last Post: July 13th, 2008, 05:19 PM
  4. Heater Blower Motors
    By Jovinblak in forum Range Rover Mark II / P38
    Last Post: June 8th, 2008, 03:45 AM
  5. heater vs. A/C blower
    By rich in forum Range Rover Classic
    Last Post: December 12th, 2005, 12:16 PM
