How to enter Radio Code
Results 1 to 15 of 15
Thread: How to enter Radio Code
    December 13th, 2008
    18
    I have a '97 LRRR 4.0 SE and the radio died. I pulled the radio to check the fuse but all is ok. I got the radio code from a LR dealer. Dealer suggested I disconnect neg. battery terminal for a few minutes, reconnect and enter code. So, I disconnected for 5 minutes and turned on the radio to enter the code but all I have is a lit blank screen. The radio/cd will play for 2-3 minutes when I press the On and BND buttons together but then shuts off leaving a lit blank screen again. When the radio/cd is on there's a beep about every second. With the screen blank there's no indication when to enter the code. I know this sounds confusing but is there anyone who can suggest how to properly reset everything so I can enter the code?
    Thanks in advance for any help.
    August 26th, 2007
    8,482
    Re: How to enter Radio Code
    when i replaced my battery, the radio displayed "code" on the display when turned on.
    if your is playing a cd etc, even for a minute, something else is wrong. mine wouldnt do anything until it got the correct code.
    i fear its not the code that is upsetting the cart here.....
    martin
    '03 L322 HSE
    '04 DiscoII - wheeling rig
    April 23rd, 2007
    Royston, Hertfordshire, UK
    108
    Unorthodox I know, but take it out of the car, put it in a SEALABLE bag and bung it in the freezer overnight.
    Take it out of the freezer, leve it in a warm dry place for a few hours then put it back in the car. it should fire up as normal.
    The person who told me this couldn't tell me why but it does 'break'the code'. To be honest, I haven't had to try this with my RR head unit but it worked on an old Alpine I had in the Merc.
    '98 4.6HSE Cosworth
    BiGas sequential LPG & Mark Adams chips
    Love it!
    August 26th, 2007
    8,482
    Quote Originally Posted by Dorian
    i will be extremely interested in the results of this trick!
    OP, keep us posted!
    martin
    '03 L322 HSE
    December 13th, 2008
    18
    Ok, I know we are gullible Yanks but this sounds hilarious. None the less, I'll give it a try and let you know if it works.
    December 13th, 2008
    18
    Quote Originally Posted by vjm530
    UPDATE: It's in the freezer as we speak. (I can't believe I'm doing this) Next update in 12-14 hours.
    December 13th, 2008
    18
    This strange and unorthodox (tongue in cheek) method did not work for me. Any other suggestions?
    December 13th, 2008
    18
    Any suggestions from anyone on how I can get the 'Code In' screen to materialize? There must some sequence of radio buttons that is preventing access to the screen. After disconnecting the battery and reconnecting, pulling the radio and reconnecting, all I get is a blank lit screen that beeps (for a code) when I press the 'On' and 'BND' buttons at the same time which allows the radio/cd tp play. This lasts for 2 minutes and then shuts off leaving a lit blank screen again. I don't think there's anything wrong with the player. The key is getting the screen to show 'Code In' so I can re-enter the Code for activation before the 2 minutes are up. At least that what it seems after all the options I have tried.
    April 23rd, 2007
    108
    Had my battery out this morning, (long story - another time).
    Reconnected battery and started car. switched on radio normally, not with the BND button down. Got 4 dashes and just tapped in the code and bingo!
    Best of luck
    '98 4.6HSE Cosworth
    Love it!
    April 26th, 2008
    Vienna, Austria
    7
    Hi,
    have you tried pushing and holding the buttons BND and MAN (the one between the arrows) for about three seconds?
    Regards, Korkut
    November 28th, 2008
    are u even sure that the LCD even works? could be only the light is working
    December 13th, 2008
    18
    Quote Originally Posted by monase
    No, I don't know but shouldn't I be able to punch in the Code since that is the default position when you turn on the radio? I thought the LCD is just for 'indication' of what is being read at the moment . . . or?
    Thanks for your help.
    December 13th, 2008
    18
    Quote Originally Posted by kork
    Hi,
    Regards, Korkut
    Thanks Kork. It worked. The LCD does not show (must be burned out) but I pressed both that you mentioned, punched in the Code and it plays. The LCD doesn't show anything but at least the radio/cd plays which is all I need at the moment until I can find a reasonably price replacement unit. Thanks again from across the globe.
    December 13th, 2008
    18
    Everything is working great now but looks like the LCD is out like you suggested. Do you know if this is replaceable and how to fix it w/o sending it out for $200?
    January 24th, 2009
    save youre self the worries! get an after market radio!! i did for my 1998 range rover and been happier then a pig eatin bacon!!
  1. Radio Won't Let Me Enter Code - How to Reset It???
    By E36 Phantom in forum Range Rover Mark II / P38
    Last Post: February 28th, 2014, 02:37 PM
  2. radio code
    By vande_v in forum Range Rover Mark II / P38
    Last Post: October 12th, 2008, 08:43 AM
  3. how to enter the code into the Clarion Head Unit?
    By LIRA in forum Range Rover Mark II / P38
    Last Post: August 21st, 2007, 02:52 PM
  4. Figured out radio code Need help w/radio functions
    By pog in forum Range Rover Classic
    Last Post: November 27th, 2006, 12:40 PM
  5. Is there a radio code
    By HSE in forum Range Rover Mark II / P38
    Last Post: July 7th, 2005, 11:19 PM
