rave cd
Results 1 to 15 of 20
Thread: rave cd
    September 4th, 2008
    san jose , costa rica
    28
    rave cd
    hi there , have tried to download the rave cd from green oval three times now ! not very good with computer techniques . i have a acer computer with vista installed . would appreciate any help . thanks
    2000 range rover HSE
    Maltby, WA USA
    13,608
    Re: rave cd
    What is the issue? Is the download not finishing? Are you unable to run it?
    "It takes a lot of little things, but the biggest thing it takes is to stop making excuses."
    1988 Classic, 1991 Classic, 1993 LSE, 1995 LWB, 1997 HSE, 1998 Granite, 2001 HSE
    September 4th, 2008
    28
    Re: rave cd
    it downloads fine . but cannot open it ???
    Maltby, WA USA
    13,608
    Re: rave cd
    When you click on "rave.exe" what happens?
    September 4th, 2008
    28
    Re: rave cd
    i dont get "rave.exe" once it has downloaded . my computer opens " NTI CD/DVD maker" automatically . do you think i should download it again , and try open it with another program ?
    June 13th, 2004
    Emu Plains, NSW, Australia
    5,306
    Re: rave cd
    Is it an ISO file that needs to be burned to a CD-ROM?
    What is the file extension for the download?
    Ron Beckett
    1995 Range Rover HSE 4.6 V8 auto
    2007 Yamaha XJR1300
    2006 Suzuki DL650 V-Strom
    RIP Bucko (1979-2008 - Riding on forever)
    http://p38arover.com/lee_pix/bike_caricature-avatar.jpg
    June 13th, 2004
    5,306
    Re: rave cd
    I just had a look at the site.
    Did you read the para that says:
    This file is an image of the Land Rover Rave CD, if you cant read this file straight away, you need to do one of two things. Either write the image to a CD, using Nero or similar - note you need to write the image to CD, not just write the file. Or you can get hold of a program such as 'Alcohol 120%' which will create a virtual CD drive on your PC, from which the file can be read, this negates the need to write a CD.
    Ron Beckett
    2007 Yamaha XJR1300
    September 18th, 2007
    Solihull, UK
    1,704
    Re: rave cd
    You can also right click and open with winrar (if you have it installed) and it lists the compressed files, from where you can extract or install.
    Kamran
    1998 - 4.0 - Ex Police 'Special Vehicle' - Single Point LPG
    http://www.clicksmilies.com/usersmil...e_steering.gif
    September 4th, 2008
    28
    Re: rave cd
    ok , downloaded winrar . tried to open . but , says " archive is either in unknown format or damaged " . is there some "dummy proof" way of downloading it ? like i said before , not too familiar with all computer termanologies . feel like downloading again , but , takes long time
    June 13th, 2004
    5,306
    Re: rave cd
    What is the file extension?
    Ron Beckett
    2007 Yamaha XJR1300
    September 4th, 2008
    28
    Re: rave cd
    sorry to be ignorant , but dont know what " file extension " means ?
  13. #12
    Maltby, WA USA
    13,608
    Re: rave cd
    It has been so long since I downloaded all of the RAVEs I completely forgot that it is an image file. Many apologies. I used Nero to burn them to discs and then copied the files to harddrive. I have the discs for backup and files on drive for regular use.
  14. #13
    September 4th, 2008
    28
    Re: rave cd
    thanks rrtoadhall , busy downloading "nero" and will try again . thanks to all others who posted replies . hope it works this time
  15. #14
    October 27th, 2007
    Kansas
    199
    Re: rave cd
    captainviv - you will have to put a blank CD in your CD tray and let your NTI? software burn it for you.
    Sorry I have never used NTI (Ninja?) CD mastering software so your on your own there.
    A file extension is the three letters after the dot in the file name on your hard drive.
    You may not be able to see this depending on how you have your explorer "view" set.
    However you should be able to right click on the file in question and click "properties"
    in the drop down list that appears. That will tell you the "File Type" ie extension.
    1998 & 9/8th's 4.0S (GEMS) 81,000.
    ..... at the feast of egos
    everyone leaves hungry .....
  16. #15
    September 4th, 2008
    28
    Re: rave cd
    thanks Rioja Red , have copied it 3 times now with NTI . nothing appears on cd , so , broke them as not to get confused . still have about 11 blank disk left , so hopefully i dont run out ....
  1. RAVE CD
    By Manks in forum Range Rover Mark II / P38
    Last Post: June 3rd, 2012, 03:53 AM
  2. RAVE CD
    By nikolai in forum Range Rover Mark II / P38
    Last Post: May 5th, 2011, 07:21 AM
  3. rave pdf
    By brian.kehoe in forum Range Rover Mark II / P38
    Last Post: July 9th, 2008, 10:47 AM
  4. Rave cd
    By Ksk228 in forum Range Rover Mark II / P38
    Last Post: October 6th, 2006, 01:51 PM
  5. Rave Executable File Needed - (RAVE.exe)
    By cbf in forum Range Rover Mark II / P38
    Last Post: February 5th, 2006, 02:17 PM
