Well I'm having a heck of a time trying to get my new head unit working in my truck at all. I have it connected through an ISO connector to the JVC harness that goes to the HU. Thanks to the crutchfield pin-out for 11 speaker systems I was able to wire that fine. The HU stays on even without the key put to Accessory. When i switched the wires for "ACC" to the "Constant", it then work correctly and only turns on when the key is put to Accessory. I have no sound from any of the speakers however.
So then i take the door cards off to see what's going on and lo and behold the PO must have started to swap out the HK system for something else but neglected to leave the HK system in. So basically i had the wiring still installed from the HU to the door but no speakers in the doors. (which would explain why no sound) So what should I do now? I'm guessing now's the time to get new speakers and not have to worry about the Ambler Attenuator (although i do have all the parts to build one at my workbench). Has anyone got any recommendations for speakers to replace in the factory locations? I'm hoping they're standard sizes so I don't have to try to source out another HK system.
LinkBack URL
About LinkBacks
