How do I check Transmission fluid without going to dealer
Results 1 to 14 of 14
Thread: How do I check Transmission fluid without going to dealer
    February 6th, 2007
    83
    The owner's manual says a land rover dealer must check and service the transmission fluid. Is there a way for me to do it?
    1992 Range Rover County SWB (Help)
    2012 Range Rover Sport SC
    2004 Discovery II (Son's)
    2007 Range Rover Sport SC (gone but not forgotten)
    2005 LR3 SE (gone but not forgotten)
    2001 Range Rover HSE (gone but not forgotten)
    2011 Honda Odyssey Tourning Elite... I know, I know...
    1965 Ford Mustang 289 K-Car
    LIFETIME CONTRIBUTOR p38arover's Avatar
    June 13th, 2004
    Emu Plains, NSW, Australia
    5,355
    Do you have the workshop manual CD - commonly called RAVE?
    Ron Beckett
    2007 Yamaha XJR1300
    RIP Bucko (1979-2008 - Riding on forever)
    Gone:
    1995 P38A Range Rover HSE 4.6 V8 auto
    1996 P38A Range Rover HSE 4.6 V8 auto
    1983 Range Rover classic 3.5 litre V8 auto
    1986 Range Rover classic 4.6 litre V8 auto
    1995 Discovery 1 300TDi auto
    1984 LR 110 SW 3.5 litre V8
    1964 LR Series IIA Trayback 202 Cu inch 6-cyl Holden
    February 6th, 2007
    83
    I do, guess I should have started there?
    March 20th, 2006
    San Diego
    246
    Quote Originally Posted by USAFBUckeye
    Yes, the information is there. Remove fill plug, insert finger. Level should be right at the fill plug. Fill until fluid spills out.
    Brett
    2001 30th Anniversary Edition RR
    Premium Member kmagnuss's Avatar
    May 10th, 2006
    Sarasota, FL
    3,600
    Quote Originally Posted by Brett San Diego
    Brett
    Not totally right.
    Vehicle must be running and at operating temperature. Cycle the gears from P to 1 a couple times, then put it back in P. (or neutral??? can't remember now).
    THEN get dirty, pull plug, insert finger, fill until it comes out.
    Crooked Rod Charters www.crookedrod.com
    Tarpon... everything else is just bait
    June 2nd, 2006
    Vegas . . . Largs Vegas . . . Scotland
    642
    not quite either :P
    autobox is supposed to be checked when cold iirc.
    So, start it up,
    cycle through the gears
    put in Neutral
    disconnect filler pipe from side of sump.
    the correct level should at the lip of the filler hole.
    so either some will dribble out ( too full )
    or you put some in until it starts to dribble back out.
    2002 4.4 HSE Mk3
    23,542
    Quote Originally Posted by fisha
    not quite either :P autobox is supposed to be checked when cold iirc.
    So, start it up,
    put in Neutral
    I'm not sure here, but I don't think he has filler pipe such as the early models. The 2001 I worked on recently only had drain and fill plugs... no pipes. Somewhat like checking level in the difs.
    June 2nd, 2006
    642
    agreed. but the hole is in the same place on both filler pipe and non filler pipe models.
    personally, the dipstick on the filler pipe is useless anyhow ... i just undo the filler at the sump end.
    2002 4.4 HSE Mk3
    November 1st, 2004
    Genesee, Colorado USA
    1,308
    autobox drain / refill 99 & up
    Quote Originally Posted by RAVE
    GEARBOX - DRAIN AND REFILL - FROM 99MY
    Service repair no - 44.24.02
    Drain
    1. Position vehicle on ramp.
    2. Apply handbrake and position chocks under front and rear wheels.
    3. Position container under gearbox.
    4. Remove gearbox drain plug and discard sealing washer.
    5. Refit drain plug using new sealing washer and tighten to 15 Nm (11 lbf.ft).
    6. Remove filler/level plug and discard sealing washer.
    Refill
    7. Refill gearbox to bottom of filler/level plug hole with correct grade of fluid.
    8. Ensure gear lever in the ’P’ position, start engine and move selector lever through all gear positions and back to ’P’ position.
    9. With the engine idling, continue filling gearbox until a small thread of fluid runs from filler/level orifice.
    10. Refit filler/level plug using a new sealing washer and tighten to 30 Nm (22 lbf.ft).
    11. Lower vehicle.
    In the Maintenance section for "up to 99", it says Ensure vehicle is level, and NOTE: Check the fluid level only when the
    engine and gearbox are cold.
    So, when it mentions "ramp" in step 1 above, I park the truck level in the garage at standard ride height, and slide under.
    Also, before draining, I made sure I was able to remove the fill plug, same as I do on the diffs.
    Jim
    2000 NAS HSE
    2005 NAS HSE
    May 10th, 2006
    Sarasota, FL
    3,600
    Where's my crow?
    March 20th, 2006
    San Diego
    246
    Quote Originally Posted by kmagnuss
    Not totally right.
    Yes, thank you. There is that little detail about the car running while you check and fill.
    Brett
    May 10th, 2006
    Sarasota, FL
    3,600
    I meant my crow to eat crow. Since I acted like I knew it all, and was only marginally correct. My apologies for misguiding the misguided.
    November 1st, 2004
    1,308
    Where's my crow?
    I'm gonna just hang on to it, I'll be needing it sooner or later...
    Jim
    2000 NAS HSE
    2005 NAS HSE
    May 10th, 2006
    Sarasota, FL
    3,600
    I think there's something in the air...I've been wrong a few times lately. Maybe I need to start drinking again.
  1. This Transmission Fluid OK
    By gisham in forum Range Rover Mark III / L322
    Last Post: August 26th, 2010, 12:16 PM
  2. Transmission oil/fluid
    By JeremyD in forum Range Rover Mark II / P38
    Last Post: January 9th, 2010, 11:43 AM
  3. Transmission fluid change
    By ero187 in forum Range Rover Mark II / P38
    Last Post: October 18th, 2007, 12:37 AM
  4. Transmission fluid check
    By sandman in forum Range Rover Mark II / P38
    Last Post: September 14th, 2006, 10:39 AM
  5. transmission fluid overfill
    By k18cas in forum Range Rover Classic
    Last Post: January 15th, 2006, 11:31 AM
