Driver seat adjustment, door lock and steering column don't work, ground???
Results 1 to 4 of 4
Thread: Driver seat adjustment, door lock and steering column don't work, ground???
    March 25th, 2013
    Holland
    17
    Ok been hunting this problem for a while since i bought my 2003 HSE last year.
    It was slowly dying on me.
    Seat adjustment would work for half a second and adjusting the seat bit by bit tapping the switches.
    Steering column almost the same, but last month just before it died completely, tapping the controls for the column would only move it down, even when i puched
    the handle up for like 20 times.
    Now i have the steeringwheel in a verry uncomfortable full down position, but luckily the seat is now stuck in my best position.
    I've already did quite some research here, first checked the fuses but their al ok. Checked out the spindle for the column adjustment described in another
    thread but looks like the nylon lock nut is just fine. Also managed to get the seat adjustment panel out and check the connections. wich seemed fine, no wear.
    sprayed them with electrical spray and prayed when i put it back but still no go....
    Now my last guess is that since it is all in sync going out, and even the lock is acting up on the drivers door, like its getting less power than it needs to get the actuator to push the lock.
    could it be a grounding issue and where to look?? if i move the controls either on the seat or the column they all still give a slight click but don't get it to move anymore....
    any guesses on where to look for grounding issues / connection issues other than the seat control switch panel??
    Thanks for reading!
    March 25th, 2013
    Holland
    17
    Re: Driver seat adjustment, door lock and steering column don't work, ground???
    oh by the way i should maybe add that the heating function still works like a champ
    March 25th, 2013
    Holland
    17
    Just ordered a used seat switch from the uk, but without the memory function, wondering if it would work. I think the memory function should only be in the seat switch?
    this part was only 35€ plus shipping opposed to the 280€ part with the memory function (Seat Switch/Computer ( BMW Part No 61.31-7 119 867)
    And since i'm already living with no functions for 3 months i think i'l manage to live without the memory functions....
    now pray that it's the fix, íll report back!
    CJD
    CJD is offline
    August 17th, 2011
    Southlake, TX
    777
    All of those functions go through a small micro connector located on the seat lower side trim...you know, the trim that is always broken! So likely the side trim panel has shifted, crunching the micro connector.
    John
    2004 322 RR HSE
    Southlake, TX
  1. Replies: 1
    Last Post: August 5th, 2013, 05:05 PM
  2. Steering Column & Driver Seat Controls Inoperable
    By gw2doc in forum Range Rover Mark III / L322
    Last Post: March 13th, 2010, 07:57 AM
  3. Telescopic adjustment on steering column faulty
    By Lee-J in forum Range Rover Mark II / P38
    Last Post: January 18th, 2010, 02:59 PM
  4. Driver and passenger locks don't work
    By stonecutter in forum Range Rover Mark II / P38
    Last Post: November 24th, 2009, 06:19 AM
