2004 - key won't turn in ignition
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 15 of 46
Thread: 2004 - key won't turn in ignition
    JUNIOR ROVER LEBoyd's Avatar
    July 5th, 2009
    Houston, TX
    905
    Talking 2004 - key won't turn in ignition
    Tonight my key would not turn I the ignition.
    I pulled fuse 18 and reinstalled and this reset the immobilization system and the key would turn and the truck will start and run (drove 75 miles after this and pulled the fuse a second time to start it again.)
    Everything else seems to work. The key locks and unlocks the doors, the cruise works, etc.
    When the truck is turned off the steering wheel will not lock.
    The battery reads 14.0v when the truck is running and 12.55v when the truck is turned off.
    I'm thinking battery (one year old interstate), but am interested in other's thoughts.
    Any suggestions are welcomed.
    Thx
    2004 L322, 265/50R20 Yokohama tires. "Mrs. Jones" ("We've got a thing going on")
    SENIOR ROVER Mrmerlin's Avatar
    January 20th, 2010
    Philly PA
    1,435
    Re: 2004 - key won't turn in ignition
    try pulling the key out turn it 180 degrees and insert it ,
    if it works then the transponder might need to be moved inside the key
    Stan
    April 28th, 2013
    Northern Virginia
    2,413
    Generally this is a failure of the Steering Lock ECU, which is only serviceable with the entire upper column itself.
    I have had them come back to life after a few power cycles, but usually not.
    The SL ECU controls both the locking of the column, and the ignition switch. If the column lock/unlock motors cannot do their job correctly, it faults, and will not unlock the ign. switch. The ignition switch is also commanded unlocked when the remote is used to unlock the vehicle, which is why resetting power to it will give you one cycle.
    There was recently a member here who wired up a switch to cycle power to the SL ECU, to be able to reset power to it without pulling the fuse.
    A used column will work, if you can find one in good condition.
    Dave
    Land Rover Master Tech
    July 5th, 2009
    Houston, TX
    905
    Quote Originally Posted by RoverGuy7 View Post
    Merlin, rotating key did not work.
    Dave, does this mean I should be able to continue to pull the fuse until I find the column? Is there something else I can test to narrow down that it is this ECU?
    Thx guys.
    April 28th, 2013
    Northern Virginia
    2,413
    The only 'test' would be to have someone with a T4 pull the Steering Column Lock History, which will show the faults that it has. I have not seen anything other then this cause what you're describing, with the column staying unlocked.
    Can you hear the column try to lock/unlock itself at all when the key is inserted and does not turn.
    Yes, resetting power should give you one unlock cycle for the key each time.
    Dave
    July 5th, 2009
    Houston, TX
    905
    I do not hear the locking attempt. Is this indicative of the ecu being bad or my hearing being bad (which it is .
    April 28th, 2013
    Northern Virginia
    2,413
    ECU, or motor itself, but might want to have someone else take a listen too, as when it's failing, it will be much quieter then normal.
    Dave
    July 5th, 2009
    Houston, TX
    905
    What else does it control? Might I try something to see if it is the ecu? What do you mean about the"motor"?
    April 28th, 2013
    Northern Virginia
    2,413
    SL ECU doesn't do much except the column and the key.
    The motor being the part that physically locks/unlocks the steering column.
    Dave
    July 5th, 2009
    Houston, TX
    905
    Okay thanks for all the help!
    July 5th, 2009
    Houston, TX
    905
    A temporary work around is to not remove the key from the ignition. I have found that the key will continue to turn if not removed. I simply placed a black cloth over the key so it's not obvious that a key is in the ignition.
    April 28th, 2013
    Northern Virginia
    2,413
    That will work for right now, as it will not try to re-lock itself until the key is removed. However, you will be keeping a few different electronics alive in doing so, so the battery may very well drain down if left too long like this. I would not let it sit for more then just overnight like this without a secondary power source for the battery.
    Dave
    July 5th, 2009
    Houston, TX
    905
    This is true in regards to the battery. I didn't add it to my work-around post because I expected members would already realize this... If not managed properly it will kill your battery.
    July 23rd, 2013
    houston, texas
    17
    I had the same problem on a 2004 HSE that I bought, guy said it was a bad battery so i bought it planning on replacing the battery boy was i wrong. The only way mine would crank after i killed it was pulling the fuse or disconnecting the battery.
    First I disconnected the battery and removed the center console and cleaned the ignition switch (amazing what comes out of that switch) (long story short)
    After farther trouble shooting and reading i removed the side vents, top dash, glove compartment, headunit, middle dash, steering wheel and shrouds.
    At the right side of the steering coulmn is a silver cap held in with 5 roll pins i decide to keep going ( remember a steering coulmn is $4500 from RR). I discovered the solenoid was bad and was never sucking in when 12 volts was applied (just for grins i put it on my test bench applied 12 volts would not suck in but would hold its self in)
    When key is turned off power is sent to that relay and the steering wheel lock is then activated. When key is put into the igntion the steering wheel lock is relased and solenoid is released.
    Long story short found a used steering column for $1600 replaced and going to part my old one out.
    July 5th, 2009
    Houston, TX
    905
    @RR2004ML, looks like I'll need to do all of that also. Had you torn your RR apart like this before? How long did it take?
  1. Key won't turn in ignition
    By zem in forum Range Rover Mark II / P38
    Last Post: August 31st, 2013, 04:25 AM
  2. Key won't turn in the ignition
    By avo in forum Range Rover Mark III / L322
    Last Post: January 12th, 2013, 08:07 PM
  3. Ignition key won't turn
    By robyjak in forum Range Rover Mark III / L322
    Last Post: July 28th, 2012, 11:25 AM
  4. key won't turn in ignition.
    By scottuf in forum Range Rover Mark III / L322
    Last Post: September 3rd, 2011, 08:58 AM
