Checking trans fluid, temp to check?
Results 1 to 4 of 4
Thread: Checking trans fluid, temp to check?
    June 24th, 2010
    106
    I know it's suppose to be around 40 but is there a way to check it at home without having a way to check temp? I have an 06 RR with 85k on it. I wanted to make sure my levels on it are good. Thank you for the help in advance!
    SOLIHULL ROVER Mrmerlin's Avatar
    January 20th, 2010
    Philly PA
    1,576
    Re: Checking trans fluid, temp to check?
    pretty simple get your IR gun and shoot the pan
    Stan
    April 28th, 2013
    Northern Virginia
    2,415
    On the 6 speed, it can be done up to 50*C, but I prefer cooler. Best way to do it is just first thing in the morning, and be quick about it.
    With the truck cold, go under and crack the fill plug loose, but don't remove. Have fluid and some sort of pump ready in case you need to top off. Start the truck, let it idle for about a minute in P. Get under and remove the fill plug, there should be a small stream coming out. If not, top off until there is, and put the plug back in. Don't take more then 5 minutes for the whole thing after starting it, as the fluid heats up pretty quickly.
    Dave
    Land Rover Master Tech
    June 24th, 2010
    106
    Thank you Roverguy7. Now I just have to figure out how to get my Rover started. lol
  1. AMSOIL 5HP-24 Trans Fluid
    By timc in forum Range Rover Mark III / L322
    Last Post: July 24th, 2012, 06:50 AM
  2. Trans temp and ibus command list for MY 03 - 05
    By jhepworth in forum Range Rover Mark III / L322
    Last Post: September 1st, 2010, 01:38 PM
  3. Changing F&R Diff Fluid/X-Fer Case Fluid/Trans Filt & Fluid
    By afox04 in forum Range Rover Mark II / P38
    Last Post: September 26th, 2008, 07:30 AM
  4. Checking the brake fluid level - handy tip
    By adm333 in forum Range Rover Mark II / P38
    Last Post: December 5th, 2007, 01:35 AM
  5. Automatic Transmission fluid level checking help?!
    By Timbo in forum Range Rover Classic
    Last Post: March 2nd, 2007, 12:40 PM
