Range Rover (transmission fault:limited gears only)
Results 1 to 14 of 14
Thread: Range Rover (transmission fault:limited gears only)
    May 13th, 2013
    Cape Coral , Fl
    Hello everyone. Hope all is good , I have recently received a code on my 2006 RR HSE saying "transmission fault limited gears only"... She does have 96k miles and is now stuck in third gear. It goes into park/reverse/drive fine but will only go into third. Check engine light is on as well. It's very random though, I can leave my house and it will be stuck in third but sometimes when I go to the store and shut it off and come back then it's fine (sometimes) . Other times its still in 3rd . I took it to the dealership and they think the transmission needs to be replaced but they're not sure so I have an appt this weekend . Also my battery is .5 volts lower than normal so I dont think my battery is the issue .When it is stuck in third it shifts ridiculously hard into third and reverse. But when the transmission is fine , it shifts very smooth. Thanks, Phil
    May 17th, 2013
    Kirkland, WA
    Re: Range Rover (transmission fault:limited gears only)
    I woke up yesterday with the same fault message. From what I've been reading, it can be a number of issues. Have you taken it in to the mechanic yet? Diagnosis? I still need to take mine in.
    July 8th, 2013
    San Francisco
    Hello all, I have the same problem now. Did you guys have your rebuilt? Anyone have a good mechanic in the San Francisco bay area?? Thanks, Tam
    August 15th, 2006
    Blackburn, UK
    1,993
    Clearly your transmission is selecting limp home mode because the transmission ECU has detected a fault either with itself or elsewhere within the transmission. You need to get the diagnostic codes read to determine the cause. It's never a bad idea to check the fluid level too (see attached).
    Phil
    May 17th, 2013
    Kirkland, WA
    I've had the same issue. I had my regular guy look at it (independent Range Rover specialist), also had a highly recommended independent transmission specialist look at it and finally consulted with a tech at my local Range Rover dealership...result...the valve body. The cost for parts and labor is estimated at $3,100-3,300 plus tax.
    August 15th, 2006
    Blackburn, UK
    1,993
    It’s frustrating that the valve blocks are simple to disassemble and vacuum test but ZF have chosen not to make the individual parts available, beyond the solenoids :
    and the intermediate plate :
    However, Sonnax are producing a Zip Kit for the 6HP26 :
    Phil
    Guest
    July 9th, 2013
    New Olreans, LA
    I just picked up a 2006 Range Rover Supercharged with 93K. Beautiful car. I checked the car out before buying by talking to the service departments and verifying what was done throughout its mileage. No recalls or defects...just routine maintenance. Drove the car home about 800 miles and one week after getting it home the car tripped into limp mode and the dash read "Transmission Fault - limited gears only". The next day the check engine light was stuck on. Now the car ran fine up to this point so there was no signs of anything mechanical. After thinking it through and realizing the Interstate battery might be the original on the car.....I changed it and the CEL cleared and all is well. Makes sense now considering these cars have a ton of sensors and modules that rely on a properly working battery. My point is that my old battery caused all of this! Hope this helps someone.
    May 7th, 2014
    Jackson, MS
    Has this happened again after changing your batter? I changed the battery and it did fix the problem...however about a year later I have the same transmission fault and it is stuck in 3rd gear. thanks.
    February 22nd, 2005
    Tasmania, Australia
    590
    Rover45 what are the results of all the tests in the electrical sticky for your car?
    Greg Hind
    http://www.skirecord.com
    1999 4.6 HSE
    April 12th, 2015
    BOGOTA, COLOMBIA
    Hi: I have the same problema in my RR HSE 2006. Coincidentially a week ago while I was driving comfortably the SUV shut off as if something electrical had gone. I parked in the Street, lit the flashers and was calling for a pick up truck when I decided to call my mechanic. I told him "listen to the way it sounds..." . In that instance the car started perfectly again. IT HAS TO BE THE BATTERY.
    November 17th, 2015
    Hawaii
    Aloha! I am having the same Transmission Fault Limited Gears message on my 2006 Range Rover HSE. I had a diagnostic done 2 months ago with no issues, now this message comes up all the time. No issues running but when I switch gears to Park or Reverse I hear a thump when changing gears. Does anyone know a good mechanic in Hawaii (Oahu)? Taking it to the dealer costs tooo much.
    October 13th, 2015
    Jamaica, NY
    Hey how u guys doin, anyone got this problem fixed yet, what causes it
    22,913
    All sort of things can cause this message. As we have no clue what year or model you have there is little more that can be recommended except pull the actual code or read the existing threads.
    I've learned so much from my mistakes,
    I am thinking about making a few more.
    June 1st, 2016
    Hello,
    I'm having similar problems with my RR HSE 2006. Did you end up replacing the battery? Did it correct the 'transmission' error message?
  1. TDV8 Transmission Fault: Limited Gears Available
    By neiloakley in forum Range Rover Mark III / L322
    Last Post: November 16th, 2012, 03:43 AM
  2. Transmission fault- limited gears... While in the middle of Montana...
    By Kcal in forum Range Rover Mark III / L322
    Last Post: July 18th, 2012, 03:16 PM
  3. Transmission Fault Limited Gears Available
    By ICYUNVAngela in forum Range Rover Mark III / L322
    Last Post: February 26th, 2012, 11:05 AM
  4. Transmission Fault... Limited gears available.
    By Slykmr in forum Range Rover Sport / L320
    Last Post: May 17th, 2009, 03:01 PM
