Ticking noise from top of Engine
Results 1 to 2 of 2
Thread: Ticking noise from top of Engine
    November 14th, 2012
    England
    4
    Well another one of those ticking noises from my Range Rover Vogue V8 Petrol 2002 L322, started ticking at the top of the engine, driver side, seems to be coming from the front of the block, startd a day after i brought it, took it back and they changed both heads complete which did the trick but just after 3 weeks the ticking has started again, i cant believe it, put in some engine flush today and will run this untill tomorrow, when i will drop te oil and replace but i am not sure what ells i can do to solve this issue, any thoughts?
    August 26th, 2007
    8,488
    Re: Ticking noise from top of Engine
    Search will bring you too many results to count, so I suggest using that first.
    '03 L322 HSE
    '04 DiscoII - wheeling rig
  1. Ticking noise after oil change.
    By peby14 in forum Range Rover Mark II / P38
    Last Post: August 1st, 2014, 06:53 AM
  2. Ticking noise; transmission issue?
    By ckonesy in forum Range Rover Mark II / P38
    Last Post: March 30th, 2012, 09:01 PM
  3. Ticking Noise
    By mark9930 in forum Range Rover Classic
    Last Post: August 26th, 2009, 11:01 AM
