05 Range Rover Steering ECU/Ignition lock problem
Results 1 to 10 of 10
Thread: 05 Range Rover Steering ECU/Ignition lock problem
    August 25th, 2012
    Doha, Qatar
    Unhappy 05 Range Rover Steering ECU/Ignition lock problem
    My 2005 Range Rover has a problem where recently the ignition lock won't release unless I remove and replace Fuse 18 in the passenger fuse box.
    I can tell the steering lock does not work any more as it does not give that flick of the steering when I turn the key anymore and there is no "click" until I remove and refit the fuse.
    I have checked all the fuses relative to immobiliser etc in the passenger fuse box, but have not checked fusible link 2 since I don't know where it is or how to get to it.
    Based on what I have read across the forums, it seems to be a fault with the steering ECU and I am led to believe I need to change that and the ignition switch together. Before I fork out almost USD 4000 (which is what the dealer here in Qatar wants) I want to rule everything out.
    I would appreciate some guidance from all you experienced guys out there. Particulalrly I would like to understand why, if the ECU and//or the ignition switch is goosed, why, when I remove and replace fuse 18, after a short time delay it all works and stays working unless I remove the key.
    I'm desperate and need your help.
    February 6th, 2013
    Baltimore, MD USA
    Re: 05 Range Rover Steering ECU/Ignition lock problem
    Same problem here. Did you have any solutions?
    September 27th, 2013
    Cayman Islands
    4
    I have the same problem with my 2004 HSE and am searching the forum for the answer, but haven't found it yet. Did you manage to fix yours?
    Just bought the car yesterday with an allowance on the price for the USD7,000 quoted by the dealer on island here for a new steering column. I'll be happy to keep removing and replacing the fuse for that price, but I'd love to find the fix.
    I've downloaded the workshop manual and looking forward to learning the car as future problems arise! It's my first Landy, proud to be joining such an active and well informed forum
    November 8th, 2004
    Miami,Fl. USA
    919
    Welcome to the forum, look here:Battery fully charge but engine won't turn over
    ______________
    Range Rover
    L322 4.4 2003
    Ex-P38A 4.0 1997
    Ex-R.R.C. 3.9 1994
    Cayman Islands
    4
    Thanks Zubi - I was really grateful to read your solution. I believe the problem with mine is the steering lock not engaging, therefore it's not getting the correct 'steering unlocked' message. I found the thread about the Greek mechanic who drilled a small hole in the steering column body to lubricate the lock mechanism and get it working. That'll be my future option!
    In the meanwhile I'm putting together the same/similar solution as you - an inline fuse and switch from fuse 18 until I get the time to investigate the column in more detail. The only difference is I'm going to try using male spade connectors to attach to the fuse receptacle rather than fuse taps - as no one carries them over here. Did you find a good route for the wiring to keep it all looking nice in the glove box?
    Thanks again, James
    November 5th, 2013
    Uk
    Hi chaps. I joined the forum because I have a 10 year old range rover that has caused me no end of bother! - latest issue is the Steering ECU. I tried the toggle switch approach for fuse 18, but it didn't work. So I then tried the disconnect battery option, which didn't work. I managed to find on another forum this article. - which meant drilling a hole in the steering column and squirting in some WD40.
    anyway - it worked for me - so hopefully this'll work for someone else and will mean that I save someone the 7000 USD cost of a replacement!! by the way - I should add - this was a last resort for me - so if you do this, its at your own peril. - can't see why it might cause issues, but just a general disclaimer!
    all the best
    Disco.
    November 8th, 2004
    Miami,Fl. USA
    919
    If your gona drill, Be careful, I tried it, I ended up drilling right into the windings of the solenoid that makes this thing lock/unlock. Drill slowly and a bit at a time.
    ______________
    Range Rover
    L322 4.4 2003
    Ex-P38A 4.0 1997
    Ex-R.R.C. 3.9 1994
    November 15th, 2014
    fort lauderdale
    Have a issue with 2005 RR like these. Any new solutions?? Disconnect battery and problem is solved. Will try fuse 18. Can you point me to the thread for drilling / WD40.
    Thanks in advance!!!
    In Fort Lauderdale
    November 5th, 2015
    Canton, GA
    71
    November 17th, 2012
    Düsseldorf in germany
    59
    Change parts from ECU, the fuse 18 trick will have function only for some weeks, drilling and
    WD40 is dangerous and will bring problems after some month because the elecronic platine dont like WD40. Best rgs, Uli
  1. 03 range rover tailgate lock problem
    By mrtallguy in forum Range Rover Mark III / L322
    Last Post: September 5th, 2015, 10:59 AM
  2. Steering column and ignition lock issues
    By Desert pilot in forum Range Rover Mark III / L322
    Last Post: November 5th, 2013, 04:58 PM
  3. 1988 range rover ignition warning chime problem
    By DanaChampion in forum Range Rover Classic
    Last Post: July 13th, 2012, 08:44 AM
  4. 04 RR Key Wont Turn / Steering Lock problem NEED HELP!
    By nomadicgreg in forum Range Rover Mark III / L322
    Last Post: February 5th, 2011, 05:59 AM
  5. steering lock problem and fix
    By Escape in forum Range Rover Mark II / P38
    Last Post: January 17th, 2008, 12:44 AM
