i am locked out of my range rover!! Battery died! 2004 range rover hse
Results 1 to 14 of 14
Thread: i am locked out of my range rover!! Battery died! 2004 range rover hse
    May 28th, 2012
    Edmonton, Canada
    12
    Hi, my range rover had been parked for around 2 months, and i had decided to take it out of its natural hibernating state. As i grabbed the key to my range rover and began to approach it, i pressed the unlock button. The doors did not open, assuming the battery had died (i had replaced the battery around 15 months ago, and had barely driven on it) , i thought i would get in my vehicle open the trunk and boost the range rover. As i tried to find a place to insert my key to open my door on my 2004 RANGE ROVER HSE, to my surprise i was unable to find a way to open my door, since i could not find anywhere on the outside of my vehicle to put me key in. Know i dont know what to do, my battery is dead and i am unable to get in to my range rover.
    Could you guys please tell me how i could boost my battery or even get inside my vehicle without doing any harmful damage. I was thinking maybe i could get under my truck and somehow unlatch the hood, would that work?
    P.S: IS THERE SOMETHING I AM MISSING?! i think its beyond ridiculous how this vehicle does not take my key. Is there something i am missing, is there a hidden spot, to insert your key?
    PLEASE HELP ME !!
    November 28th, 2010
    79
    Re: i am locked out of my range rover!! Battery died! 2004 range rover hse
    Side marker on the front fender is a constant positive. Pull the indicator and shave the positive wire, put the charger/jumper positive on this wire and negative on the frame. Unlock the door and charge it properly.
    This has been covered in pervious posts.
    How to unlock your RR/L322 with dead battery
    2004 HSE Albuquerque, NM
    April 2nd, 2007
    560
    2003-2009 Range Rover's have a key hole on the drivers door. 2010+ have a key hold but you must pop off the outside cover to gain access. i am locked out of my range rover!! Battery died! 2004 range rover hse-land_rover_range_rover_2004_door_handle_cups_chrome_4pc_set_oem_n_a_na.jpg
    2011 Range Rover HSE LUX
    SENIOR ROVER Mrmerlin's Avatar
    January 20th, 2010
    Philly PA
    1,375
    your door handles probably have the aftermarket covers on them,
    see if you can pry off the cover thats over the key lock,
    this should let you open the door if the side marker light doesnt work
    Stan
    November 28th, 2010
    79
    Sorry, I did not see that you neglected to find the key insert on the driver door handle. Pull of aftermarket covers if equipped before you try the side marker trick.
    Quote Originally Posted by rcshauger View Post
    May 28th, 2012
    Edmonton, Canada
    12
    THANK YOU GUYS SOOO MUCH !! that was a huge stress reliever, i never noticed there could have been a cover on the door handles. My dad had put a STRUT body kit, on my range rover and i never noticed they changed my door handles but apparently i did. Since i am studying for exams, i wont be able to check on the door handle and to see if i could pry it open till Saturday. I will tell you guys how it goes.
    And one last question; My battery keeps dying, through the chilling winter weather my range rover was parked in my garage for 3 months, and myself being so oblivious i forgot to disconnect the battery; Unfortunately my battery had died. When the spring seasons began to kick around, i boosted my range rover and let it charge for about 10 minutes, and then i had driven it to my uncles house, and parked it. When i turned it off, and went to turn it back on my battery needed another boost. Would this be the battery's fault or my alternator?
    i really hope its the battery since i dont want to pay the labor and parts to replace my alternator...
    Thanks guys .
    April 12th, 2010
    Australia
    156
    Dont boost you may cause a host of other problems , I fried the diodes in my alternator (500) with a simple boost . If the battery is flat replace it with a new one or trickle charge the battery over night.
    Sounds to me you need a new battery , Get a good one these rigs need a good power supply to run all the systems.
    10/2002 mk3 Range Rover vogue
    4.4l 130000kms
    Range Rover Clasic 86
    May 28th, 2012
    Edmonton, Canada
    12
    could i possible slowly charge my battery ? by an actually battery charger? what kind of hosts of problems are you talking about. I am actually a little afraid right now since i have boosted it twice now since i got my range rover.
    Thanks for the reply
    22,520
    "Boosting" is not the issue. Following proper jump start proceedures should not do any damage. Boosting a dead battery and going for short drive does not charge it up and only further weakens the battery. Only a long slow charge can properly bring a battery back to life if it hasn't already given up the ghost. Best bet for resurecting a battery that has been completely drained multiple times is to remove the battery and trickle charge it on the workbench.
    How come "you're a peach" is a complement but "you're bananas" is an insult?
    Why are we allowing fruit discrimination to tear society apart?
    November 28th, 2007
    Orlando, Fl
    1,115
    Another best bet is to take your RR to an Autozone or Advance Auto Parts (or equivalent in your area) and have them load test your battery. They have the equipment to tell if the battery is in good shape, or if it has one or more dead cells.
    I have an Interstate Battery dealer that's local to me who can test the battery and makes a good quality replacement battery. I've had my current Interstate battery in there for a few years now, and have had no problems. It can sit for weeks at a time between operation with no problem.
    Good luck!
    '03 Range Rover
    All Stock
    Black
    22,520
    X2 on the Intersate option. THey are terrific to work with. If you are lucky enough to have a main outlet close by check them out. THe main outlets often have no label batteries for half the price. THese are Fully warranted and operationally perfect Interstate batteries that have a chip or a scratch so they don;t sell them on at full price due to a cosmetic fault.
  13. #12
    July 23rd, 2013
    houston, texas
    17
    I leave the emergency cord hangout on the rear hatch for this reason, its not visibly and good for this.
  14. #13
    October 2nd, 2015
    Tennessee
    10
    I have gotten in to mine before by using the side marker light. Today, I tried and it would not work. The key won't open the door because the key isn't manual in the door either, its also electric. BMW Morons!!! SO, what do I do now. I let it sit for about 20 min with the wires attached to my truck to the side marker light wires. I know it was good because the light was on. However, none of the other side lights were on??? What now???
  15. #14
    August 26th, 2007
    8,202
    Quote Originally Posted by Gatorm View Post
    ...........What now???
    Use the search maybe? It was covered a week or so ago
    '03 L322 HSE
    '04 DiscoII - wheeling rig
  1. Range rover engine has died on a right turn twice?
    By Nickws in forum Range Rover Mark III / L322
    Last Post: February 28th, 2012, 04:09 AM
  2. 2004 range rover help
    By sal94107 in forum Range Rover Mark III / L322
    Last Post: February 14th, 2012, 02:07 PM
  3. 2004 range rover
    By presise in forum Range Rover Mark III / L322
    Last Post: June 28th, 2009, 08:00 PM
  4. Range Rover died on me last night -- battery or alternator?
    By miami m3 in forum Range Rover Mark III / L322
    Last Post: March 20th, 2008, 10:48 AM
  5. 2004 range rover key battery
    Last Post: December 11th, 2007, 01:12 PM
