Blocking protection problem – front wipers
Results 1 to 15 of 19
Thread: Blocking protection problem – front wipers
    August 15th, 2006
    Blackburn, UK
    1,999
    I’ve been having a problem with my front windscreen wipers just stopping for no apparent reason while they’re switched on (I don’t mean the ‘intermittent’ function – this is in both normal and fast ‘continuous’ modes).
    Having read the workshop manual I know that the wiper mechanism has a ‘blocking protection’ function which cuts the power to the wipers if they’re switched on and there’s no wiper park signal received by the Body Control Unit for a period of 16 seconds (e.g. if the wipers are frozen to the windscreen or something physically obstructs them from moving). The BCU then only turns the power back on again after waiting 3 minutes or if the ignition is turned off & on again – and sure enough that’s exactly what mine do, although neither waiting for 3 minutes or keying off the ignition is much of an option at 70mph on the third lane of a motorway while passing a truck that’s throwing up huge quantities of spray.
    Although I always believe that an ECU is the very last thing that should be blamed for a fault I thought I’d better first check that it wasn’t sat in a puddle of water or something due to a leak. I removed the passenger seat to inspect the BCU and its connections and everything looked absolutely fine.
    Body control unit lives under passenger seat
    BCU
    I used my Faultmate to check for DTCs for the Body Control Unit and sure enough it had stored “Wiper motor blocked, park switch or wiper relay defective”. The wiper relay only costs £5 so I thought I’d try that first
    Wiper relay is mounted next to transfer box ECU behind the battery
    August 15th, 2006
    Blackburn, UK
    1,999
    Re: Blocking protection problem – front wipers
    but when I phoned to order one I was told by the Land Rover dealer that they’d never sold one before – the clear implication being that it was unlikely to be the relay at fault. I therefore decided to buy a new wiper motor/linkage assembly instead.
    I’ve now fitted it and - guess what - the problem is still there . I took the old motor apart to examine the park switch and there’s nothing obviously wrong with it
    Cam on motor drive gear which activates park switch
    Wiper park switch
    I’ve therefore now ordered a wiper relay and am waiting for it to arrive. In the meantime I’ll have to keep my fingers crossed that this is going to fix the problem.
    I just wondered if anyone else had had a similar experience with their front wipers?
    Phil
    JUNIOR ROVER LEBoyd's Avatar
    July 5th, 2009
    Houston, TX
    905
    Quote Originally Posted by RRPhil View Post
    Maybe the reason they hadn't sold any is because people buy them from BMW or somewhere else not realizing that the LR dealer's price isn't that bad? I just did a quick check for the part and there are several places that sell them - although I think it's interesting that they are not English (I did see German on ebay). Generally, relay failures aren't really unheard off (i've had relay failures on my Tahoes more than once), so I'm surprised about the "surprise" of the dealer.
    Just some thoughts I had about this. Anyway, i hope the relay works for you.
    2004 L322, 265/50R20 Yokohama tires. "Mrs. Jones" ("We've got a thing going on")
    August 15th, 2006
    Blackburn, UK
    1,999
    I'm pleased to report that it was the wiper relay causing the problem - and it cost just £6 to replace it
    Just a shame that I’d already spent £127, unnecessarily, on a new wiper assembly before getting to this point!
    Phil
    January 30th, 2010
    forest of dean [united kingdom ]
    76
    well done phil
    a thread with a conclusion , some threads start of well but never get an ending
    2000 p38 4.6 v8 30th aniversary prins sequential multi point lpg
    1990 3.5 v8 defender 90
    2004 4.4 v8 l322 vogue prins sequential multi point lpg
    SOPHOMORE ROVER medcapequip's Avatar
    October 5th, 2009
    Los Angeles, CA
    285
    Nice insight and story. Anyone know if the relay would cause the wipers to stay in the up position?
    2003 Range Rover HSE
    Los Angeles, CA
    May 10th, 2006
    Sarasota, FL
    3,573
    I'm actually really surprised that you believed the dealer and went against your gut on this one. Most of us (yourself included) try to actually diagnose the problem and not just throw parts at it until we get lucky... you did that here but second guessed yourself. Glad it worked out in the end but it sucks you blew 127 to remind yourself that you're smarter than the average dealer parts changer.
    Phil
    September 14th, 2013
    Leeds
    Does anyone know where this relay is on a 2009 5 litre petrol model please?
    May 24th, 2015
    Found mine in Tdv8 in the ECU compartment on the right side under the bonnet.
    April 3rd, 2015
    United States
    11
    It is in the back if the Battery it has a vertical black lid with two clips on top that hold it.
    I replace my relay and my wipers still not working.
    Any extra ideas?
    April 3rd, 2015
    United States
    11
    Ok, i am getting crazy with this! I try all this
    - replace relay 3 times
    - replace the steering wheel wiper switch.
    - send direct power on the top of the relay connector to test the wiper motors and the wipers move
    - replace the Body Control Unit because mine has coffee outside from the previous owner
    and they still not working. Any ideas?
    August 25th, 2015
    Cleveland, OH
    4
    SilRangeMKIII, let me know if you have already figured it out. The other day I have to jump-start my '04 RR and left the ignition turned in the ON position (not too smart). Now the front wipers are dead, the front windshield washer pump is not spraying and the locks are not responding at all. On the other hand, the rear wipers and washer pump is working and the rear door unlocks from the remote just. I have checked all fuses yesterday and today I plan to swap relays. Is it safe to simply swap relays in order to trouble shoot this? Are all rated for the same current? Is there a simple way to verify relays? Thanks.
    August 25th, 2015
    Cleveland, OH
    4
    I was able to get the BCU fixed. For some odd reason the Body (electronics) Control Module BECU located under the passenger seat was stuck in Transportation Mode. This can happen if the battery drains out and during jump-starts. I have used the RSW Solutions AllComms tool with my laptop and was able to re-code the BCU. After re-code I cleared the "Transportation Mode" using the same tool. I was not aware that the software for this diagnostic tool got updated to Version 3 which can now debug BCU units or code new ones if you have to install new BCU, something only dealers used to be able to do. Nice way to avoid the dealer or having to pay a technician for it. Thanks Storey Wilson!
    mauritzio
    2004 Ranger Rover HSE
    April 3rd, 2015
    United States
    11
    Quote Originally Posted by mauritzio View Post
    Thank you mauritzio for this input, I guess is time to expend more money on the RSW AllComms. I have two OBD computers one Snap-on tools that helps with a lot of issues and a Maxidas that is pretty much open. When i replace the BCU after looking for the best option to reprogram it, it cost me $250 for that is pretty much the cost of the AllComms.
    One extra thing does any boady has the lap wipers wire schematic (diagram) I find out that the previous owner crash the left hed lamp and replace it and i want to be sure that the hedlamp wipers are working fine.
    -2003 Silver Range Rover HSE MKIII/L322 M62 BMW Engine on San Diego CA.-
    January 2nd, 2014
    Newport Beach, CA
    67
    The headlight wiper wiring schematic is in RAVE under the Wipers and Washers section.
    2005 Range Rover HSE, 4.4L
  1. 2003 RR HSE front windshield wipers & front washer motor stopped working
    By bobst2003 in forum Range Rover Mark III / L322
    Last Post: May 22nd, 2012, 11:23 PM
  2. Front Protection Bar fitting....WOW
    By lear60man in forum Range Rover Mark III / L322
    Last Post: March 26th, 2010, 09:43 AM
  3. New Front Protection HRA BullBar fitted
    By Rat_RR02 in forum Range Rover Mark II / P38
    Last Post: March 10th, 2009, 04:16 PM
  4. Looking for a A-FRAME FRONT PROTECTION BAR for 2003 Range
    By daly in forum Range Rover Mark III / L322
    Last Post: July 4th, 2007, 11:37 AM
  5. '05 front wipers
    By scottuf in forum Range Rover Mark III / L322
    Last Post: April 16th, 2007, 01:19 PM
