2004 HSE battery replacement
Results 1 to 15 of 20
Thread: 2004 HSE battery replacement
    February 28th, 2012
    Idaho
    Hello Everybody,
    Not a new subject here but one I need some info about. Pls bear w/me. I need to replace the battery in RR. The Optima brand batteries are popular among your group and i'd like to install either an Optima D31A Yellow top or a D31M Blue top for their deep cycle advantages. Yet I have found that battery product search engines indicate that neither of these batteries will fit. But the compartment space appears adequate and other model years can accept these battery sizes. Will they fit in my 2004 RR HSE?
    ? #2 Any precautions on that incendiary positive battery lead? I have disconnected the negative lead to recharge the existing battery but have not ever pulled the positive lead.
    ? #3 The open hood access to the rear battery compartment is tight. Can the hood be opened any wider without fully removing the thing?
    Thnx.....
    JUNIOR ROVER LEBoyd's Avatar
    July 5th, 2009
    Houston, TX
    905
    Re: 2004 HSE battery replacement
    Welcome to the forum.
    If you pop off the hydro lifts on the hood at the fender the hood will fold back (check youtube for a video on this).
    Personally, I chose the Interstate. It has a long full-replacement warranty and longer prorated. I think it was 6 or 8 years prorated and 3 or 4 replacement. I paid $165 for it.
    2004 L322, 265/50R20 Yokohama tires. "Mrs. Jones" ("We've got a thing going on")
    July 5th, 2009
    Houston, TX
    905
    Also, if you disconnect the negative first you should not have a problem with the positive. (I'm guessing you do not have the owners manual. There is a negative and positive connection outside the battery box that allows for easy charging.)
    February 28th, 2012
    Idaho
    Thank you. Found the video on you tube and it does answer some of my questions. I am still curious as to the fit of the replacement battery. The battery in place is some 15 inches wide, 6 or so inches deep and the entire depth including the lead attachments is over 9 inches. And there seems to be space beyond these dimensions. Yet the battery product search engines for this model/year do not indicate that it will accept the physical size of these Optima batteries even though they are comparable in size. Yet these batteries are deemed 'a fit' for 2003 HSE models. Is this some branding quirk associated with the BMW manufacture or what? I'd hate to get a battery that would not fit.
    July 5th, 2009
    Houston, TX
    905
    Unfortunately, since I bought the Interstate I can't help you on the size issue.
    23,146
    I for one have never understood anyone having issues with the physical size of a battery, especially on an older rig, when their rigs are up and running. You hop in the car, drive to a supplier and have them match up or closely match what you have. If they don't have it on the shelf they open up their book or hop on a terminal and browse by dimension and positive terminal location and order it. I don't know of any suppliers that don't have a size chart for phone or special orders. Even msot web sites have dimensions and positive side listings.
    February 28th, 2012
    Idaho
    Hmmmm..... Well, ToadHall, I only report what I am exposed to trying to problem solve on-line. I have no idea why battery manufacturers or their retailers would uniformly indicate a size limitation. Pardon me for not being inclined to drive around town when such assets as the web and this forum present better options than some clerk at an auto supply outlet. I would have thought that if there was a peculiar and real reason for this situation that I might find the answers here more readily and accurately. The solution I have chosen is to purchase a product I know I can return should the need arise. Thank you for your wise counseling.
    SOLIHULL ROVER linuxfreakus's Avatar
    October 10th, 2009
    Sedona, AZ - USA
    1,812
    The Optima batteries are fine. I just don't recommend them. Too many seem to be defective (according to what I read).
    The Odyssey will fit just fine also, although you may need to replace the ground cable with a slightly longer one (I did). I actually got the DieHard Platinum PM1, which is identical to the Odyssey, both made by the same company. Don't let them tell you it won't fit. It does, and mine has been flawless so far. Being sealed, hopefully it won't leak acid everywhere like the interstate did. Time will tell.
    2004 Range Rover Westminster (sold)
    2007 Range Rover SC (sold)
    Arizona, USA
    November 17th, 2011
    Hickory Hills IL.
    226
    I totally agree with Linux. I purchased the Diehard that he suggested in a post awhile back and it's been flawless. 300 bucks seems high but you won't be sorry. I had to install a longer ground cable too, but it fits perfectly. Jim
    23,146
    Quote Originally Posted by Deniles View Post
    Wow. Sorry you felt the need to take my post as a personal statement towards you. I was simply making a general comment. Good luck in your search.
    11,043
    Quote Originally Posted by linuxfreakus View Post
    That's the main selling point of AGM batteries, no? Virtually no chances of leaks or acid fumes, even with the battery mounted upside down. My guess is that AGM will become the automotive industry standard in a few short years. If you shop around, there is a much wider selection of AGM batteries now than there was just a year or two ago. Sears has a new Advanced Gold AGM (a bit cheaper than their Platinum and available in new sizes), AutoZone now offers a Duralast Platinum AGM, etc. Lots of choices, it's not just Odyssey or Optima anymore.
    October 10th, 2009
    Sedona, AZ - USA
    1,812
    Indeed it is one of the main selling points, however, if something goes terribly wrong, they do still contain acid... so there is the potential for it to come out
    The potential is far, far less than a non-sealed battery of course.
    Regarding the size, I was told point blank by multiple sales people and their mechanic that my DieHard battery not only would not fit, but would not work for starting a car because it is a marine battery. I tried to explain that it exceeds the specs of the stock battery, but they just didn't get it. I had to argue with them to sell me one (they were kept behind the counter) and they refused to install it (I did not want them to anyway!!). They even told me they did not have ANY battery they sold that would fit my vehicle. I can't say I'm surprised to see people coming to this forum to ask about batteries, because there are some foolish people working in some of these stores.
    Arizona, USA
    FRESHMAN ROVER JG87's Avatar
    April 21st, 2008
    Naperville, Illinois
    33
    I just purchased a duracell battery for my rover from sams club for $88.22 fits perfectly and great warranty. Looks like Deka east penn manufactures the battery under part number 9AGM49
    Attached Thumbnails Attached Thumbnails 2004 HSE battery replacement-sams-batt.jpg
    2004 Range Rover HSE 4.4
    JL Audio 13w7 JL 1000/1v2
    Angel Eyes
    Strut grille
    March 6th, 2012
    memphis, tn
    Hey JG87 I own a 2003 Range Rover HSE and am looking to replace the battery. Mind If I ask how well that Duracell is holding up for you?
    April 21st, 2008
    33
    The battery is holding up great. I can leave my rover for 3-4 days now without starting it even in the cold and it cranks up fine.
    Angel Eyes
    Strut grille
  1. Replies: 17
    Last Post: February 16th, 2017, 01:55 PM
  2. Upgraded battery for L322/Petrol/2004?
    By richardb20 in forum Range Rover Mark III / L322
    Last Post: September 13th, 2011, 11:35 PM
  3. 2004 RR Low Key Battery Message
    By isleofbones in forum Range Rover Mark III / L322
    Last Post: December 30th, 2010, 01:51 PM
  4. battery drain overnight 2004 RR
    By livste in forum Range Rover Mark III / L322
    Last Post: April 17th, 2009, 11:39 AM
  5. 2004 range rover key battery
    By presise in forum Range Rover Mark III / L322
    Last Post: December 11th, 2007, 12:12 PM
