Hello All:
Turning 95K miles with no problems, but only had it since 89K, so thought I would tackle a few things now that I am back home and can work on it... Most of the 6K miles since purchase have been highway... and last 1,000 miles was towing 5,000lbs... Surprisingly Stable Towing Machine!
This is what I have planned:
*Mann Oil Filter & Air Filter
*New BEHR Radiator (VERY small leak along passenger side of radiator)
*Coolant Reservoir to Thermostat Hose (at some point, this hose was left unclipped and rubbed up against a pulley, but luckily did not burst... I noticed the deep rub marks while inspecting the bottom of the engine)
*FEBI Transmission Filter, Pan Gasket, & O-Ring
FLUIDS:
Engine Oil: Mobil 1 0W-40
Transmission Oil: Mobil LT71141
Coolant: BMW Blue Coolant
Coolant Additive: Redline Water Wetter
QUESTIONS:
1. Front & Rear Differential Oil: AMSOIL Severe Gear 75W-90 or ??? How much for drain & fill?
2. Transfer Case Oil: Castrol BOT 26 FMB 1 or ??? How much for drain & fill?
3. Transmission has never been opened... Perform a "regular" transmission fluid & filter change (~5 qts) or "complete" by draining from cooler return hose as well (closer to 10 qts)?
4. DIY instructions for COMPLETE coolant flush & bleed including heater core & drain through block plug? (I've looked for this & can't seem to find the complete flush instructions)
5. Anyone fitted a better-than-stock transmission oil cooler?
6. BONUS POINTS QUESTION: Correct bolt size to secure the power steering hose bracket which runs from the pump to the gear? Attached just behind the transmission cooler...
THANKS!![]()
LinkBack URL
About LinkBacks
