2007 range rover sat nav/radio/cd on default Land Rover screen
Results 1 to 10 of 10
Thread: 2007 range rover sat nav/radio/cd on default Land Rover screen
    December 26th, 2011
    Wales uk
    4
    The on/ off button has an orange flashing light all the time Have checked the fuses and no sidn of water corrosion in boot. Help husband not happy !!
    JUNIOR ROVER LEBoyd's Avatar
    July 5th, 2009
    Houston, TX
    666
    Re: 2007 range rover sat nav/radio/cd on default Land Rover screen
    Well... I don't know if this is the problem but in the MKIV manual I found (for BMW) the light will flash in regards to the telephone (which probably not your issue) or in regards to the ventilation/heater ("direct operation activated"). I don't know if the ventilation/heater is part of the 07 module, but you can find this on the menu.
    You don't indicate whether or not everything is working or not. Is it?
    2004 L322, 265/50R20 Yokohama tires. "Mrs. Jones" ("We've got a thing going on")
    FORUM ADMINISTRATOR umbertob's Avatar
    9,097
    See TSB below, addressing MY07-09 RR (and 06-09 RRS) infotainment system lockups. If the touchscreen freezes on the Land Rover logo during "boot" and the audio system won't work it may be a MOST communication bug and this software fix may apply. Check your VIN to make sure you are within the range of affected vehicles first. If you're out of warranty (likely on a MY07 at this point) the repair will probably be on your dime, but it looks like an hour or so of labor only, no parts. A small price to pay to make husband happy again.
    PS: This is a North America TSB, just noticed you are abroad... But still worth checking into as there may be a corresponding bulletin out for European spec vehicles.
    Attached Files Attached Files
    December 26th, 2011
    Wales uk
    4
    Hi Thanks for the reply Nothing is working ,it has locked everything out .Tried disconnecting battery and checked fuses ?
    July 5th, 2009
    Houston, TX
    666
    Unfortunately, I own (and therefore work) on the 03-05 model and just don't have the manuals or experience to help more. Sorry.
    January 16th, 2008
    B-more, MD.
    123
    My 05 has been doing the same thing off and on. I finally got it to the dealer and they told me the amp was shorting out cause a short to the touch screen display unit. They qouted me over 1500 for the reapir. I am going to get a second opinion.
    2008 with lux package. (2005 retired)
    January 7th, 2011
    46
    Have a load test done on the battery.....
    2006 Range Rover HSE LUX
    2008 Audi A 6
    February 16th, 2012
    Oahu, HI
    Quote Originally Posted by umbertob View Post
    So I took my 06 RRS HSE in after I had this issue and read this thread. I even printed off the TB for them. The agreed and tried to load the software, but they said "it wouldn't take the software". After more than $300 in labor, I am still having the same issue. The thought it might be the amp going bad, but that is an expensive repair for "thinking" it might be bad. Has anyone else encountered this? Is there a way I can test the amp? I have done all the other easy troubleshooting I can think of (left the battery disconnected overnight, unplugged and replugged all cables at the amp and HU, checked all fuses).
    It is frustrating to have a ~$60 vehicle with no sound and no nav.
    Help!!!
    February 16th, 2012
    Oahu, HI
    So after three months of no radio and lock screen, everything came back on. The full sound and nav yesterday with no radio reception. Now today the radio has reception. A couple of weeks ago I disconnected every cable and reconnected them with no immediate change. The only other thing that is of interest is that I used the spare key FOB for the first time in months. I can't see ANY way that made a difference, but now it works. I am not holding my breathe it will last, but for now I am feeling better.
    Interestingly, the TB calls for the dealership to test the amp with a known amp beofre they can order a new one. The dealership in Oahu said they didn't have a working amp and sent me on my way with no option for repair. Awesome...
    July 8th, 2011
    New Hampshire
    73
    The only thing with the different key is that it loads a different profile. if my wife uses my Rover, then all the preset radio stations are different when I get back in and use my key. not sure why it doesn't work when you use your key, but maybe now it works, have the dealer reprogram the firmware.
    Chris
    2005 L322 HSE
  1. iPod plugin for 2007 Land Rover Range Rover Sport?
    By jaredtysak in forum Range Rover Sport / L320
    Last Post: January 31st, 2012, 10:48 AM
  2. Need A Cool Range Rover or Land Rover Loading Screen
    By 2000_328ci in forum Range Rover Mark II / P38
    Last Post: March 1st, 2011, 07:26 AM
  3. My Screen won't turn off, stuck on Land Rover Logo
    By luvleafs in forum Range Rover Mark III / L322
    Last Post: April 9th, 2010, 08:29 PM
  4. land rover logo on nav screen
    By NATEDOGG in forum Range Rover Mark III / L322
    Last Post: November 28th, 2007, 03:43 PM
  5. 2006 Range Rover Lemon --> 2007 Range Rover
    Last Post: December 24th, 2006, 09:38 AM
