Everything was really straight forward on the trailer kit with the exception of two things:
Not really sure what the problem could be. It seems really simple other wise.
- There were two relays included in the kit, a green 5-pin unit and a black 4-pin unit. I used the black unit since it matched all the other relays. If I use the green one, it causes the radio and some other things to turn on even with the key set to off. LOL So I assume the black one is right. However there isn't any indication of where to use the second relay. For use on some other model RR maybe?
- The orange wire that you connect into one of the wiring harnesses is a little confusing. The instructions seem to indicate it goes in pin 3. As I am looking at the back of the plug while it is plugged into the block (wires coming out at me), the top row left two pins are vacant, and the bottom row third from the left is vacant. I'm assuming it is the top row second from the left that it goes in and that's what I went with.
LinkBack URL
About LinkBacks
Mrs. Jones
Rocky
