Key Programming - Should I risk it!?
Results 1 to 15 of 19
Thread: Key Programming - Should I risk it!?
    January 4th, 2010
    25
    Hi All,
    I will be ordering a new key from the main dealer within the next few days
    I understand that they charge £60 for programming, but some of you guys have actually done this yourselves? Just wanted to check if its advisable and if it will actually work?! Not to fond of the idea of having no working keys if i get it wrong.
    These are the instructions I have:
    Programming a new Key
    Replacing a missing master key is quite expensive from Land Rover, try not to get sucked into the extra cost of "Dealer coding" You can do this yourself in 2 minutes by following the simple process below.
    1) Get in and close all doors. Turn ignition on and off quickly and remove the key (all within about 5 seconds).
    2) Within 30 seconds of turning the ignition off, while holding down the "unlock" button, press the "lock" button three times. Release the "unlock" button. (You may or may not get the confirmation from the door locks.) Holding the key at your head level provides best results as the key sensor is in the side window pillar.
    3) Repeat for each key you want to initialize within 30 seconds after the last one you initialized (if you have more).
    4) Right after doing the last key, quickly put the key back in the ignition and turn it on/off again to finalize.
    If anyone has any advice or expereince on this it would be ace!
    Matt
    May 3rd, 2011
    West Yorkshire, UP NORTH in the cold UK
    19
    Re: Key Programming - Should I risk it!?
    Recently had to replace batteries in my key fobs, followed the instructions. worked a treat
    http://i262.photobucket.com/albums/i...xa/Jakeeee.jpg
    Two things in a bloke's life, his DOG & his CAR!
    11,042
    On recent model years (06+) the key's EEPROM chip needs to be programmed via diagnostics to be able to start the engine. You can sync the remote yourself, but to defeat the immobilizer you need someone - dealer or independent - to program a new key first, no other ways around it. Not sure if technology on earlier model years is different, though.
    January 4th, 2010
    25
    My car is an 03 td6 - it seems like the instructions do work for a new key if its cut etc and supplied by the dealer for most people, and it could save me a few £££....i'll have a think as to if i attempt to do the 'programming' steps myself...
    November 28th, 2010
    79
    My dealer "programmed" it right there in front of me and did not charge me. Ask your service advisor to do it if you have a good relationship and are a bit concerned about messing it up.
    It really is not that big of a deal even if you wanted to do it yourself.
    2004 HSE Albuquerque, NM
    May 23rd, 2013
    United States
    40
    After buying 3 batteries I took a look here and found this - Worked great!!! 4 months of not having a working key fob sucked - Thanks so much!! Also, never realized I could open all the windows by holding the unlock button then close them with the key in the door - Thanks again!!
    September 10th, 2013
    Laval, QC, Canada
    Hi all,
    I bought a 2003 RR last week, it came with only one key and this key is in very bad shape. I ordered a new key from the dealer for 260 $ and they asked me another 150 $ for programming. When I got the key, I used the programming procedure here, it worked just fine, the first time, so I saved 150 $.
    Thanks a lot for the info.
    Regards,
    Stéphane
    Montréal (Québec)
    July 26th, 2013
    United States
    34
    Do it yourself. The LCD doesn't flash as rapidly as the instructions say but it works. Just did it yesterday after my BCM erased its settings when my battery run low.
    03 RR L322, Nissan Murano, 2001 BMW E38
    October 28th, 2013
    valencia
    Quote Originally Posted by TD6Matt View Post
    Hi All,
    Matt
    It worked for me. Just I couldn't programme the second key during the process. What has to be repetead in step 3?
    May 19th, 2014
    Long Island, NY
    260
    It took three me three times repeating the process, but it worked for me (2004 HSE).
    Thank you for posting. It saved me $129 and a couple hours of my precious time by not having to go to the dealer. It's bad enough that the key cost me over $300.
    November 7th, 2014
    Oklahoma, USA
    Awesome. Worked on a 2008 L322 HSE
    September 24th, 2014
    Chicago
    65
    I have yet to do this correctly. Tried literally 100 times or so. Now even physically turning the door lock with key inserted won't unlock! What's going on? I have to constantly press the unlock button for about a minute in order for the lock to finally open.
    May 20th, 2015
    United States
    I purchased a 2004 Range Rover HSE from a guy and the Key Fob was not working. I tried the instructions you provided and it worked like a charm. I also Had indicator lights on for hand break, Suspention inactive and a bunch of other inactive and followed instructions I read here and other places on this Blog and everything has worked!!!!!!!!! You guys are the best. Thank you so much
    June 5th, 2015
    memphis,tn
    Morning all. I'm reading that this will work on the 08 RRSC and then I read that it won't work. Any definitive answer?
    22,903
    Quote Originally Posted by gators241987 View Post
    yes...............
    I've learned so much from my mistakes,
    I am thinking about making a few more.
  1. programming
    By greenguy in forum Range Rover Mark III / L322
    Last Post: August 25th, 2011, 04:24 PM
  2. Programming Question
    Last Post: December 14th, 2008, 09:17 AM
  3. At the risk of jinxing myself...
    By Emerson00 in forum Range Rover Classic
    Last Post: February 5th, 2008, 08:24 AM
  4. key programming
    By Forumnoob in forum Range Rover Sport / L320
    Last Post: September 17th, 2007, 05:45 PM
  5. At the risk of boring you with another shuddering issue
    By usaroverman in forum Range Rover Mark II / P38
    Last Post: January 24th, 2007, 09:49 AM
