Parking sensor replacement
Results 1 to 8 of 8
Thread: Parking sensor replacement
    May 21st, 2011
    Hi,
    After searching this and several other Range Rover forums for hours, I still haven't found a step-by-step guide on how to replace the parking sensors on the Range Rover L322. After several cold Norwegian winters (with temperatures below -20 ?), some of the sensors on my Range Rover TD6 Vogue '04 are broken (one on both the front and the back bumper). Buying new ones online is both cheap and easy, but does anyone know about any good step-by-step guide on how to make the replacement? Or can anyone describe the procedure, for both the front and the back bumper? My Range Rover doesn't have any exterior accessories installed but original mud flaps.
    Thanks!
    SENIOR ROVER Mrmerlin's Avatar
    January 20th, 2010
    Philly PA
    1,378
    Re: Parking sensor replacement
    the parking sensors are snap into place parts , the trick is getting behind them to undo the snaps. For the rear bumper it has to come off to get to the sensors its not hard to remove the rear bumper cover.
    To do that open the tailgate and reach under the leading edge of the black bumper cover,
    push the 12 tabs back and up once the leading edge is free slide the cover forward about 1/4 inch remove the cover.
    Then remove the bolts on the top and bottom of the bumper cover remove the 2 bolts in each wheel well.
    then take a thin screwdriver and working from the front edge on the side ,
    put the screwdriver into the body seam about 2 inches back from the front edge and lift the handle this will push down the holding tab( wrap the driver in tape first so you dont nick the paint), gently pull the cover out then move back about 3 inches and do the next one , there are 3 clip on tabs on each side once you do one side the other is easier as you will know where to pry.
    Once the sides are loose get a milk crate and cover with blanket, place behind the bumper, gently slide it rearwards about 8 inches, stop let it rest on the crate .
    On the RR corner of the body are the sensor main harness connection,
    from underneath remove this connector from the body by twisting it to a 45 degree angle,
    it should pull free from the body then disconnect it by squeezing the tabs.
    NOTE this connector takes a lot to reconnect so make sure that both of the side tabs snap back into place.
    Reinstall after washing the bumper and replacing your offending sensors
    Note also make sure the wire harness runs about 3 inches forward from the rear lower channel in the bumper cover,
    this will prevent the wires from being cut by the metal bumper support, use good tape to hold the wires in place.
    The sensors are kinda self explanatory to replace as they have little tabs holding them into their housings.
    For the front bumper you have to remove the cover to get to the backs of the sensors use the RAVE manual to remove it there are lots of bolts and each sensor has its own separate harness
    Stan
    May 21st, 2011
    Hello again,
    Thanks for the quick reply! I'll give it a try and let you know if anything wrong happens. Seems like you know the procedure very well!
    By the way, do you know where to get a PDF version of the RAVE manual? I downloaded a .ISO-version from myrangerover.co.uk but since I'm on a Mac, I'm not able to read the software at all... perhaps borrowing a PC from someone is the easiest thing to do?
    Thanks again!
    August 23rd, 2007
    Beaverton Oregon
    646
    Quote Originally Posted by ThormodRK
    Hello again,
    Thanks again!
    An iso needs to be burned by a cd burning software. There are tools that also exist to extract an .iso but I have no idea what those tools would be for a "My first computer" (i.e. a Mac)
    FRESHMAN ROVER gyrogypsy's Avatar
    May 25th, 2011
    Weybridge, UK
    228
    Gents. I have the RAVE manual as a zip file. Let me know if you want it and I will put it on my FTP server.
    Simon
    '05 L322 V8 Autobiography. Zambezi Silver.
    December 19th, 2011
    New jersey, usa
    Hello, any chance I can access this FTP site to work on the front parking sensor wiring?
    22,520
    THe RAVE download on landroverresource.com is a standard .pdf file and viewable on mac.
    How come "you're a peach" is a complement but "you're bananas" is an insult?
    Why are we allowing fruit discrimination to tear society apart?
    March 11th, 2012
    London, UK
    Hi, this YouTube video might be helpful - it shows the front parking sensor being removed. It's from PowerfulUK
    http://www.youtube.com/watch?v=89eng...VQgH7aeP8XA%3D
    ...I hope that's not against the rules.
  1. Please diagnose my PDC Parking Sensor fault?
    By markw996 in forum Range Rover Mark III / L322
    Last Post: December 15th, 2016, 06:37 PM
  2. Parking Sensor Problem
    By rudseyrover in forum Range Rover Mark III / L322
    Last Post: January 21st, 2014, 03:13 AM
  3. alarm and parking sensor issue
    By hawee in forum Range Rover Sport / L320
    Last Post: December 16th, 2010, 01:01 PM
  4. Parking Sensor Issue?
    By unlimitedmiami in forum Range Rover Sport / L320
    Last Post: August 24th, 2009, 12:20 PM
  5. Astrodoneps Parking Sensor.
    By B16JOP in forum Range Rover Mark II / P38
    Last Post: February 27th, 2006, 09:14 AM
