NavTool Video in Motion - Install HELP
Results 1 to 6 of 6
Thread: NavTool Video in Motion - Install HELP
    August 10th, 2010
    Glenside, Pa
    60
    I purchase the Navtool VIM module and am having problems installing it. I have called NAVTool (and emailed twice) asking them to send me the instructions that were suppose to come with the module. No avail.
    It's suppose to be plug and play. I had the toushscreen module pulled out from the dash and none of the factory connectors fit into NavTool's harness plugs. Looking for help from someone who has installed the module themselves.
    Where do I plug the VIM module into - the back of the touchscreen unit? Also, I think I need an additional cable that's not provided in the kit, nor mentioned is needed on their website. Please help. Thanks
    '06 FullSize RRSC BLK/Sand: RSE w/ NavTool Hack
    2001 Disco II SE7 Blk/Sand: 2" OME Lift: ARB Bull-Bar
    Glenside, PA
    ____________
    "The greatest trick the devil ever pulled was convincing the world he did not exist, then poof he was gone"
    11,027
    Re: NavTool Video in Motion - Install HELP
    For sure you will need an interface video cable to run between RSE module and touchscreen, since it was completely missing on 06-08 RR in North America and no video playback was possible even with the car in Park. If it's like the 2006 RRS it would be Fakra SMB on one end (to plug in the available input of the same color behind the touchscreen monitor) and probably S-Video on the other end (to plug into the available port on the RSE module.) In the picture below - yanked from Navtool's web site - it almost looks like the lone cable on the bottom may be it - although it would be way too short for a Sport, since the RSE module is all the way in the rear quarters of the car, so it's quite a run to get behind the front monitor... Did you get that cable? You may need a M-F S-video extension cable to connect the two, depending on where the RSE module is mounted in a Range Rover... Just guessing, though. The module itself looks simple to install - in one way, out the other - but if you say none of the factory harness connectors match maybe they sent you the wrong module? Hope you get it sorted with them, for $450 they should at least call you back.
    August 26th, 2010
    San Clemente CA USA
    159
    I am just cusious why you chose this product over the less expensive NavTV interface? I am looking to do this soon as well, so I would love to hear your input as to why you went this direction, and if you feel there are any advantages.
    Best of luck with the install and please update as to your progress.
    August 10th, 2010
    Glenside, Pa
    60
    thanks for the replies. it turns out I will need an additional s-video cable to connnect the touchscreen to the rse module. Where is the RSE module located in a '06 RR fullsize??? Under the front glovebox or in the rear with the dvd changer??
    Glenside, PA
    ____________
    September 7th, 2012
    Texas
    I ordered the NAVTOOL for my 06 RR SC and didn't receive any instructions. I emailed them the other day and still haven't heard back. The unit I bought (RRVIMFAKRA) came with a short fakra to RCA cable which I assume needs to run from the back of the screen to the rear left (US) panel and connect to the RSE. Based on what I am reading here I would need a 12-15 ft RCA to Svideo to extend what NAVTOOL sent me. Any info or links would be appreciated. Just want to make sure I know exactly what I need before I start tearing part my dash.
    FRESHMAN ROVER 06BlackHSE's Avatar
    May 22nd, 2013
    MD-DC
    209
    The install is pretty easy. I did mine a couple years ago. See this link: http://www.navtv.com/userfiles/editor/file/manuals/OPV-1R/OPV-1R.pdf
    M
    y cable is going from the back of the screen to my micca speck hdmi 1TB and I have a on of videos/movies and pictures on it. It plays on the front screen and the 2 headrests.
  1. Video Install Update
    By WorkHardPlayHard27 in forum Range Rover Mark III / L322
    Last Post: March 19th, 2011, 11:07 AM
  2. DVD Video in Motion
    By lenk in forum Range Rover Sport / L320
    Last Post: March 6th, 2009, 09:56 PM
  3. Video In Motion
    By xLusi0n in forum Range Rover Sport / L320
    Last Post: November 12th, 2008, 02:05 PM
  4. Video in motion / Video Input
    By RoyN in forum Range Rover Mark III / L322
    Last Post: December 7th, 2006, 12:08 PM
  5. Video From NAV-TV unit- Self Install!
    By Rainor in forum Range Rover Sport / L320
    Last Post: February 18th, 2006, 01:23 PM
