Hi all,
I have a 2003, 4.4. V8 petrol Vogue and suffered some hard trouble last winter from an apparently frozen PCV system.
It frequently spilled oil from the left hand valve cover onto the manifold - which you can smell very clearly after a while.
It seemed to happen after cold damp nights, so the dealer checked the PCV hoses, the oil seperator, changed the valve cover seals 3 times,
changed the PCV hoses, the oil seperator and the complete valve assembly in the back of the intakte manifold last february.
After all, it was in the workshop about 6 times....
This was last winter. And I might remeber it being o.k. afzer the final change of the valve in the manifold back end. But might as
well had no frozy nights anymore afterwards.
Now tonight, we had the first frosty night again and it seemed to be happening again.
I had a very bad smell of burned oil aftre running a 7 km distance and parking it up at a shop.
After popping the bonnet and having the first quick check it smelled like burned oil quite clearly and the area underneath the left hand valve cover again is wet and oily...
Its were the cover sits on top of the cylinder head.
I have done a search in this forum and found some explanations of PCV hose changes etc.
So far so good. BUT! I also found a pic with what appears to be an electric heating blanket on the top PCV hoses.
Is this a genuine thing for cold areas or some aftermarket modification?
Help is much appreciated, as I seem to have a bad problem with this car not liking minus temperatures.
Apart from this it behaves well and without trouble so far.
Engine runs as intended, no warnings, no oil use, no water use, no funny behaviour.
I use it for long runs but do the occasional short trip as business makes it neccessary.
I bought it in may 09 and experienced the frist trouble last winter, and now it starts all again.
regards
heppsen
LinkBack URL
About LinkBacks
