M62 engine PCV seems to freeze up? - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 34 of 34
Thread: M62 engine PCV seems to freeze up?
  1. #31
    January 1st, 2005
    Truckee/Tahoe
    1,900
    Re: M62 engine PCV seems to freeze up?
    heppsen
    Just to confirm, when I was removing my PCV there was about 6 CC of water in the tube you mention. But I think that between combustion leak by, heat ect there would be a fair amount of water vapor produced in a closed system. Just look at all the water that comes from a tailpipe. (yes i know that it's open to the elements).
    Mark
  3. #32
    FRESHMAN ROVER vnt30017's Avatar
    August 2nd, 2011
    Atlanta GA, USA
    50
    Quote Originally Posted by Moto One View Post
    Parts are ordered, and just for good measure I ordered two sets of spark plugs.
    I was able to get the one (destroyed torks screw removed), and that also gave me access to the inside of the intake, and I was able to clean out the oil that was pooled in the rear.
    Thanks Tony for the information.
    Mark.
    I have the exact same issue. One stupid torx screw that I have spent hours trying to get off but cant. How did you manage to get it off??
    2003 Range Rover HSE
    V8 4.4 AT
    "she pulled me over..pulled me out the rover"
  4. #33
    September 26th, 2010
    86
    I am assuming you can't remove the Torx bolt because it has 'stripped'? This happened to me a couple of weeks ago when I changed mine - Someone had previously done a sloppy job and stripped one of the Tork heads. I was able to remove it by clamping a 9"' (approx) locking-pliers onto the head of the Torx bolt, as TIGHTLY AS POSSIBLE - i.e. so tight that I could not 'close' the pliers by hand, (I had to use another locking-plier tool thing to close the 2 handles together). A firm wack with a hammer then 'cracked' the bolt loose, and I was able to use a smaller pliers to unscrew it completely. I would have replaced the Torx bolt with a normal hex-head bolt, BUT there's at least 2 bolts that cannot have a normal hex socket attached, because the design of the plastic manifold valve cover housing prevents a socket to be placed over the head of these 2 or 3 bolts. Stupid design. Anyway, I have replaced all Torx bolts with Hex bolts where possible, to prevent possible issues in future with stripped Torx heads. By the way, my system blew in a couple of places at the same time, following a very cold 2 days - where the 2 smaller hoses connect to the other parts. I'm assuming both smaller hoses had never been changed, because they both had the original hose-clamps attached, as opposed to the screw-thread hose clamps that you would normally see after a repair. Mine had 139,000 miles when it blew - I'm surprised it didn't happen sooner. The good news is that I had all parts in stock, as I knew I wanted to change the whole system soon as a 'preventative' measure.....
    PM me if you need some moral support....
    Simon Nevill
    Madison, Wisconsin
    (Ex-Brit from Devon)
    Adriatic Blue / Sand
  5. #34
    August 2nd, 2011
    Atlanta GA, USA
    50
    Quote Originally Posted by nevill View Post
    Thanks nevill. I will PM you. I just called a local indy shop and they quoted me 400 labor to replace the intake cover. I refuse to let one bolt cost me 400 when I am so close to doing to doing it myself!
    V8 4.4 AT
  1. Help: could valley pan leak cause OSV to freeze somehow?
    By linuxfreakus in forum Range Rover Mark III / L322
    Last Post: March 1st, 2011, 01:46 PM
  2. 2010 Nav screen freeze
    By swimmingriver in forum Range Rover Sport / L320
    Last Post: March 17th, 2010, 07:11 PM
  3. Dripping coolant and freeze plugs
    By lrscott in forum Range Rover Mark II / P38
    Last Post: September 27th, 2009, 12:46 AM
  4. Any preference for anti-freeze in '03 HSE?
    By ketel in forum Range Rover Mark III / L322
    Last Post: September 6th, 2007, 06:53 AM
  5. Leaking anti-freeze
    By goinboardn in forum Range Rover Mark III / L322
    Last Post: July 9th, 2007, 08:56 AM
