Hi guys,
I am down in New Zealand and have a 2002 Range Rover with the ZF 5hp24 trans. On Monday it decided to thump in to drive and then lock itself in Failsafe Mode. Which of course was perfect timing as I had to move house 400 km North this week, so ended up getting vehicle transported to new City.
I am a mechanic and here is a quick run down of the story:
1. Bought at 64,000 km
2. Auto oil and filter replaced at 70,000 km, with proper Esso fluid and genuine filter. Managed to get around 7 litres in.
3. Radiator replaced at 120,000 km due to coolant leak, trans oil cooler is in the rad yes?
4. Vehicle has done 140,000 km almost on the dot and I had done around 100km in the morning, absolutely NO signs of anything different, drove perfect.
5. Picked up empty trailer, drove 25km, stopped at work and left vehicle running for around 20 mins, went to pull away and it moved and then lost drive before THUMP and then Failsafe Mode and stuck in 4th/top gear. This resets with key off but just repeats the process.
6. Had codes read on vehicle and had(from memory now so not exact words) 1. Internal slip mechanical failure 2. Incorrect gear ratio
7. Started it next morning cold and vehicle drives perfect until it gets remotely warm, so I checked oil level and condition and was slightly dark/burnt looking.
8. Drained oil but left filter in, managed to get around 5 litres back in but has made no difference to function.
So......... anyone have any ideas? I have dropped it at a trans specialist today who will get back to me on Monday as he says even with the above failures logged it could still be an electrical fault along the lines of a speed sensor??
Should I need to take it out, luckily my new boss is a top guy and we will be removing it on one of his brand new hoists in his new workshop :dance: . I would just order all the bits from UK/USA, as parts prices in NZ are verging on ridiculous, and would undertake the rebuild myself. Auto trans are new to me though, I am a VW/Audi Tech and have tried to steer away from the Auto internals, but with my own money it is slightly different. `)
Any help much appreciated.
Barry.
Barry.
