Driving on different sized spare tire temp. Is it okay?
Results 1 to 11 of 11
Thread: Driving on different sized spare tire temp. Is it okay?
    May 3rd, 2017
    Las Vegas, NV
    11
    Had a bad gash surface and need to buy replacement tires for the front. My car is setup with the stormer rims on Yokohama Prada Spec-X 285/35/R22 and the spare is the original 12' supercharged 20's on Michelin 255/50/R20.
    I believe I have heard issues can arise with the 4wd systems and having mix matched rims. I hope to have the new tires tomorrow but the tire order may take until Monday... Is it safe to drive until then?
    Premium Member Keralis's Avatar
    March 21st, 2016
    Upper & Lower Wisconsin
    345
    Re: Driving on different sized spare tire temp. Is it okay?
    While you may not notice any changes, and the LR systems are most likely smart enough to counteract the change.. I would absolutely not drive with mismatched wheels, because parts are expensive, especially when you have a choice not to need them.
    16' Kubota RTVX900 (It Rolls Coal..)
    2005 Range Rover HSE Bonatti Grey on Ivory
    1995 RRC LWB, 25th Anniversary
    2017 Honda Grom on White
    2017 Range Rover HSE Aintree Green on Ivory
    ——————————--British Humo(u)r——————————
    23,528
    Oh good grief Charlie Brown. As a temp situation you will have absolutely no issues. Don't hit the freeway at 80MPH, don;t make any fast corners, and be careful not to curb shot that stylish black doughnut rim.
    Seriously... you will be fine for a temp. The issue that folks will brow beat you for will be running rolling circumference differences between sides or front to back... long term. As you have the forethought to replace a pair on an "axle" you will be fine with no ill impact or major drama.
    May 3rd, 2017
    Las Vegas, NV
    11
    Thanks for the input! Definitely temporary, I wish they had the tires in stock to replace today but hopefully can get them on no later than Monday. Sadly life does not stop in the meantime... unless of course it would hurt the baby... then it becomes a different story :p
    FRESHMAN ROVER rovingryan's Avatar
    November 4th, 2016
    Oregon
    16
    You will be fine even for a relatively extended period. Mismatched wheels really has little to do with it and width doesnt matter, the only concern is overall diameter. Your stock tire is 30" and your new tire is 29.8" good enough that you probably will never notice.
    1984 110 CSW
    2007 L322 Vogue
    August 15th, 2006
    Blackburn, UK
    2,020
    There is only a 2.4mm difference between the rolling radii of the 22” tyres and the 20” tyres (assuming the same amount of wear). Tyres nominally have a 9mm tread depth when new and they’re replaced at 3mm tread depth so their rolling radius changes by 6mm during the tyre’s life. If, like me, you wouldn’t worry about potential driveline damage if you had to replace a single worn tyre with a new one, you certainly don’t need to worry about the much smaller radius difference between these two tyres.
    To put this in context, if the vehicle has three brand new tyres and one worn (3mm tread depth) tyre the front and rear propshaft speeds at 70 mph (assuming 3.73 final drive ratio) will be 23 rpm different i.e. 2945 rpm vs 2922rpm.
    Phil
    March 21st, 2016
    345
    Well, I must've been tired.. I saw the difference and though "2 Inchs?!"
    Sorry
    January 29th, 2007
    Toronto,Canada
    1,459
    Keralis. You were probably just thinking about resurrecting that coupe parked in front of your house!!!!!
    2004 Epson green 242k ams few records latest diff folly also 1952 Hough payloader 1959 Nuffield 4DM
    2000 kent green 4.0 SE sold
    March 21st, 2016
    345
    Quote Originally Posted by diff View Post
    I have thought of it..
    It IS complete...
    But the frame is entirely rusted out, sadly
    Oh, and that's our hunting cabins garage! Just stores boats, a 10k mile 2000 F-150, and a few muscle cars that belong to my cousins that live up there.
    May 3rd, 2017
    Las Vegas, NV
    11
    All went well! Just got the new tires installed last night... Instead of going with 2 new 35's I decided to bite the bullet and upgrade to a bigger tire and do all four 285/40/22. Love the decision and happy to have a bit more side wall, car seems to ride better too and imo looks much better than the low profile. Went with the Nitto 420's.
    March 21st, 2016
    345
    Pictures please!
  1. TPMS "Check spare tire pressure" driving me crazy
    By southernd in forum Range Rover Mark III / L322
    Last Post: November 4th, 2016, 08:25 PM
  2. Full Sized Spare
    By WildRover in forum Range Rover Sport / L320
    Last Post: July 21st, 2009, 08:50 PM
  3. Temp gauge goes to red after highway driving
    By rcristobal in forum Range Rover Mark II / P38
    Last Post: January 10th, 2007, 09:00 PM
