60,000 mile service - $1400??
Results 1 to 15 of 30
Thread: 60,000 mile service - $1400??
    March 29th, 2006
    299
    I am curious what you guys are paying for a 60,000 mile service. My dealer quoted over $1400. When I asked for a description of work to be done, he said spark plugs, oil and filter, cabin filter, air filter and inspection.
    He also stated that the spark plugs are around $45 each. Can that be right?
    Anyone know a good independent in So Cal? La or OC.
    November 23rd, 2009
    Irvine, CA
    149
    Re: 60,000 mile service - $1400??
    Rover Doctor in Lake Forest at the Irvine Autocenter. VERY reasonable, although nothing is cheap on these vehicle.
    http://www.roverdoctor.com/
    Ricardo is the owner at 949-462-0648
    Jon Holder
    2003 Range Rover HSE - In Process
    November 15th, 2009
    24
    Not sure what year you have. I have an 06.
    Genuine Spark plugs - $11 bucks each
    http://www.roverparts.com/Parts/LR005253G.cfm?bc=ab
    Genuine oil filter - $13 bucks
    http://www.roverparts.com/Parts/4137784G.cfm
    Genuine air filter - $34 bucks
    http://www.roverparts.com/Parts/PHE000112G.cfm
    Genuine cabin filter - $29 bucks
    http://www.roverparts.com/Parts/JKR500020.cfm
    Oil - myabe $50 bucks tops
    So thats less than 250 bucks in parts at retail rates. Call it 1 hour for an oil and filter change.
    so you are telling me they are going to spend the next 10 hours doing a basic inspection at $100/h? uh.... Bring it to my house and I'll do the 1 hour of work for 700-
    BS... BTW plugs on the 06-09 are only replaced every 100k....
    March 29th, 2006
    299
    WOW - thanks for the quick replies.
    It sounds like I am thinking the same thing that you guys are about the service. What a racket. I am not afraid to pick up a wrench and do my own work, especially if it saves me a ton of $$.
    Mine is an 03 by the way.
    Anyone used the shop in Huntington Beach? Custom European Motor Cars?
    Thanks for your help and the links.
    November 23rd, 2009
    Irvine, CA
    149
    I haven't used Custom - but if you are in Huntington Beach, you can use Evosport for all your engine/transmission service work. They are a BMW specialty shop with great mechanics and know all about our motors/transmissions. If you need to get into diagnostics, then they don't have a diagnostic computer to read Range Rover - but for service work it's no issue. They are off Graham and McFadden. Tell them I sent you.
    Jon Holder
    August 15th, 2006
    Blackburn, UK
    1,995
    This is the work list for the three types of Service on early L322 models :
    viewtopic.php?f=2&t=29990
    Phil
    July 29th, 2005
    Los Angeles, Ca.
    533
    LR Pasadena quoted me $ 2,000 for 60k service. I'm @ 57k miles and performing my own service instead of the stealer.
    Oil change
    filter - 18 bucks from the dealer
    oil - propbably run you 50 to 75 bucks depending what brand you use.
    Air filter - 63 bucks from the dealer
    took less than 5 minutes to install
    Spark plug - less than hour install
    BKR6EQUP - got it from local shop $8.75 = around 72 bucks for eight.
    Checked the fluids yesterday and topped off PAS. Went to the dealer and bought power steering fluid for 15 bucks. Probably could have got a regular fluid from local shop but not sure if it is the same. While I was there I picked up a Range Rover key chain for 18 bucks LOL
    All in all I spent $ 261.00 for parts and my own time DIY. To top it off, I'm enjoying every minute of it
    Next week, I will be replacing the upper and lower hose, coolant, and cabin filter.
    Goodluck,
    Mike
    2005 Zambezi silver
    January 29th, 2010
    I paid about $1800 for my 60 month/60,000 mile service on my 2004 RR. Unfortunately I am "forced" to go to the dealer because I have an extended warranty and if I do not have my maintenance done at the dealers, they may (and probably would) use it as an excuse not to cover a problem under warranty down the road. In fact, I received a letter a year later informing me it was time for my 72 month maintenance even though I drove it less than 1,000 miles since the 60 month check - cost me another $400. It almost seems not worth it to pay for the extended warranty since I have to pay all that money to have all the "recommended" maintenance done at the dealers.
    March 29th, 2006
    299
    Thank you all for your help. I didn't realize there were so many so cal guys here!
    phil - thanks for the service list. I am going to set aside a day next weekend and bang all of this out. The only part I am not sure about is the part that says "grease wheel center surfaces." They are not talking about greasing the wheel bearings I don't think, so can anyone help me out with this one?
    As for changing the coolant - are there restrictions on whether or not this can be done on my own? Does anyone know how much coolant the system holds? I want to be sure I have a big enough vessel to catch it all.
    Is there a special type of coolant?
    Is there a special type of power steering fluid?
    Oh - I called Custom European Motorcars and they quoted me $900. Better, but I will still tackle it myself.
    Thanks!
    JUNIOR ROVER remington's Avatar
    August 16th, 2005
    California
    902
    Quote Originally Posted by rovercrazy
    You do not have to have regular service done by a dealership regardless of your extended warranty.
    2016 Range Rover HSE TD6
    2012 LR4 HSE Lux
    2010 Range Rover Supercharged
    2006 Range Rover HSE
    April 23rd, 2009
    20
    Wow, I have an 06 just got my 60,000 service at an independent dealer here in Orlando for $441, while the Land Rover dealer was $530. It cant be that much of difference in the work
    February 19th, 2010
    12
    I am in the UK where labour rates are much, much higher than anywhere aside from Moscow I have ever lived or worked. Main dealers in big cities charge GBP 140 per hour, call that USD 225and in the rural areas about GBP 115 an hour, call that USD190.
    I therefore use an independent who only does Land Rovers and my 60000 service was GBP 160 all up but excluding the poil which I provide (I use Mobil 1 fully synthetic and have done since it was first launched when I used to import it from the US). This includes a sales tax of 17.5 percent.
    So USD 1400 does indeed sound a little on - how shall I put this - the steep side.
    November 15th, 2009
    24
    for the 2006 (mine is a 2006) all the dealer will do at 60k is:
    1. change the oil and filter.
    2. change the Pollen filter
    3. change the intake air filter
    4. rotate tires (side to side)
    5. top up other fluids if necessary
    6. look around and find things to fix
    basically an oil change with a couple paper filters thrown in...
    http://www.houstonlandroverclub.com/...s/06RRtab4.pdf
    April 23rd, 2009
    20
    Quote Originally Posted by wulfraat
    Maybe this is why the cost is only $530 at the dealer, I will check tomorrow and find out what it intells
    March 30th, 2008
    Newport Beach, CA
    127
    I can vouch for the British Car service in Costa Mesa ... me and friends have been taking cars there for a while now as needed. ..
    ________________
    2006 RRS
  1. 60,000 Mile Service
    By Vortec4800 in forum Range Rover Mark III / L322
    Last Post: December 1st, 2007, 11:12 AM
  2. 30K mile service?
    By darrinturner in forum Range Rover Mark III / L322
    Last Post: January 5th, 2007, 10:04 AM
  3. 60K Mile Service
    By kjsayers in forum Range Rover Mark III / L322
    Last Post: December 5th, 2006, 06:17 PM
  4. 75,000 Mile Service
    By VB_Rover in forum Range Rover Mark II / P38
    Last Post: April 13th, 2006, 01:50 PM
  5. 90,000 Mile Service
    By jake720 in forum Range Rover Mark II / P38
    Last Post: October 30th, 2005, 11:54 AM
