Is there supposed to be water draining through that pillar? Or is there a leak allowing it in there, and then the leak in the seam allowing it to drip on the amp?
Trying to figure out if I'm dealing with one leak or two at this point.
There should be no water draining through your D pillar nor is there anywhere on the exterior where water should be getting to it. It is either a failing rear side window seal that allows water in from the side rear glass or it is a poor adjustment or seal of the tailgate that allows water in from the top corner. At least that is the only two places I've every had to repair or found for folks.
My tail gate must not have been closed tight. Went to a self car wash today, sprayed all around the tailgate area to try and reproduce it, no luck. Nice and dry inside.
you can go to the store and buy a clear shower curtain and some 3M black strip caulk from the body shop supply ,
and make your own water shedding curtain for the electrics,
Also cover the battery the the suspension switch and airlines under the battery tray.
NOTE Covering the battery will prevent acid from rinsing down the chassis and getting on the airlines and damaging them.
next time you wash your truck open the hood and see if the battery is wet .
this will happen from washing the lower cowl with the hose.
if the battery is wet then it has been washed and any acid deposits on its top will be rinsed to anything below it.
remove the battery and tray and you will find the air lines and a junction valve probably corroded and brittle from acid
If you have a sunroof it is possible its the drain from that that has got blocked causing the tracks of overflow, or has deteriorated. But that is from expierience with other cars not rr.
122.2K members
