Cat exhaust leak Ext Warranty Program Q058 - Page 3
View Poll Results: Have you experienced this small weld crack at the catalytic converter housing (2003-2005 model L322)
Voters
29. You may not vote on this poll
  • Yes, and repaired at my own expense
    4 13.79%
  • Yes, and repaired by LR prior to June 30, 2009
    1 3.45%
  • Yes, and repaired under extended warranty Q058
    11 37.93%
  • Yes, replaced more than once
    1 3.45%
  • No problem noticed
    12 41.38%
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 36 of 36
Thread: Cat exhaust leak Ext Warranty Program Q058
  1. #31
    October 4th, 2011
    Re: Cat exhaust leak Ext Warranty Program Q058
    Dropped my 05 off at the dealership because I kept getting the P2A00 code for bank 1 o2 sensor. After replacing the o2 sensors and it not fixing the problem I suspected it was the Cat. It is and the dealership is covering it under warranty. Only crappy part is they said it will take 5 days to get the new Cat in. Luckily the dealership is close by so having to take it back once the part is in is only a minor inconvenience.
  3. #32
    May 12th, 2010
    14
    Does anyone know the VINs associated with this ?? '04 starting running rough and sounds like an exhaust leak high up near exhaust manifold on passenger side. i am going to look once it cools down. but it stalls under load unless you let it sit a minute and it has the SE light on. dealer closed right now, will call tomorrow, but trying to avoid extra work now. plus it's 120 miles to the stealer and don't want to have it towed for non-related issue.
    thanks.
    rt
  4. #33
    November 17th, 2011
    Hickory Hills IL.
    70
    Quote Originally Posted by redtarpon View Post
    thanks.
    rt
    I would put a generic OBD test on it for starters and see what codes it throws and start from there. Jim
  5. #34
    May 12th, 2010
    14
    1170, 1173 i assume PCV related. still no joy taking it to local shop ( if it makes it) tomorrow. might be fuel related, it stalls out just sitting.
    later
    rt
  6. #35
    October 25th, 2008
    78
    later
    rt
    What ever came of your situation?
    2003 Range Rover HSE, 4.4L
    All Stock
    Epsom Green Micatallic
  7. #36
    April 21st, 2012
    Santa Fe, NM
    I've been experiencing this problem on my 2003 Range Rover HSE for a while now. Unfortunately, the problems cropped up around 115,000 miles and weren't properly diagnosed until recently (140,000 miles) has anyone found any luck in getting around the 120,000 mile rule of the extended warranty?
  1. Who else has an exhaust leak from the exhaust manifold?
    By JaguarS4R in forum Range Rover Mark II / P38
    Last Post: November 29th, 2009, 10:29 AM
  2. exhaust manifold leak symptoms?
    By 420P38 in forum Range Rover Mark II / P38
    Last Post: March 26th, 2009, 02:24 PM
  3. Changing exhaust due to leak-Need advice
    By afox04 in forum Range Rover Mark II / P38
    Last Post: September 26th, 2008, 03:38 AM
  4. Exhaust manifold leak or lifter noise?
    By mrpcar in forum Range Rover Mark II / P38
    Last Post: April 17th, 2007, 11:29 AM
  5. Exhaust leak
    Last Post: April 15th, 2007, 03:43 PM
