Need help with air suspension codes codes 112-116-103
Results 1 to 4 of 4
Thread: Need help with air suspension codes codes 112-116-103
    July 16th, 2008
    I just replaced both front air shocks I let the car pump itself up after waiting a while and opening the door(tricks the computer that is in easyentry mode and airs up to correct height).
    It airs up the last spring and it gets hard lock in airsusp inactive Max speed 35mph..
    I took it to the dealer to get the diff campaign done and use the $150 credit to reset the computer and I figured after 1800 on 2 new front shocks I would be good.. NO LUCK!!
    They think I need a new compressor..
    It is in air susp inactive light mode-- the orange hold light is back on. and the compressor works from time to time..
    The codes that the dealer got out of the system were:
    112- Compressor temperature static when compressor is active
    116- Resrvoir pressure static when filling
    103- Too much energy for regulation needed:front axle < this one sounds like front to rear valve block may bee leaking? No?
    If you guys have any knowledge in diagnosing and repairing the EAS system post what you think it is..
    I dont see how it is the compressor, it works all of the time and runs in short cycles(doesnt take long to get the car back up)
    What do you think?
    September 22nd, 2008
    1,858
    Re: Need help with air suspension codes codes 112-116-103
    Quote Originally Posted by williws
    What do you think?
    Were your air shocks even bad? Drivers side corner of mine kept falling over night... Turned out to be the battery leaking acid down to a rubber suspension fitting which dropped the front to the bump stops.
    July 16th, 2008
    Yes one had a large blowout and the right side had many cracks and was leaking down at night and does not do that anymore. I just have inactive light..
    November 10th, 2007
    Washington DC
    257
    Your compressor is fine I had same issue with mine I spoke with WABCO The people that make the compressor they said that Land Rover had been issued a new Software upgrade for the EAS system. This gives a higher value to the compressor temp sensor and stops the lockout due to over temp. Land Rover get to make money because the new compressor has to be programmed with the new variables from the latest disc and they pitch your compressor, hence its fixed when you ride away.
    2003 HSE with 2004,2005,2006,2007,2008,2009,2010,20011 and now 2012 Parts in it
  1. System too lean fault codes, why o why? Codes back again.
    Last Post: November 15th, 2013, 06:55 PM
  2. Air Suspension codes...Please help!
    By DSG03SVT in forum Range Rover Sport / L320
    Last Post: January 24th, 2011, 09:47 AM
  3. odb codes
    By ferret in forum Range Rover Mark II / P38
    Last Post: March 17th, 2009, 06:23 PM
  4. Check engine light and OBD2 codes.... phantom codes!!!
    By flamecycle in forum Range Rover Mark II / P38
    Last Post: September 14th, 2007, 10:22 AM
  5. EAS Suspension Rest - ECU Address Codes
    By Malafax_dand in forum Range Rover Mark II / P38
    Last Post: January 25th, 2007, 09:50 AM
