ignition key will not turn
Results 1 to 11 of 11
Thread: ignition key will not turn
    September 14th, 2007
    12
    OK, my battery went flat after standing for 2 weeks, the ignition key will not turn, put in new battery , the bloody key will still not turn , what am i missing ???. I tried the lock/unlock the car from the outside , tried the spare key, still nothing
    your help would be greatly appreciated
    April 20th, 2006
    Houston, Texas USA
    521
    Re: ignition key will not turn
    Is your steering wheel locked? Try moving it while turning the key.
    2008 Range Rover Supercharged Stornoway/Sand DVD
    http://www.uh.edu/learningleading/images/468_uofh1.gif
    12
    steering wheel moves freely,
    October 2nd, 2007
    Londerzeel Belgium
    238
    Don't panic, go back to basic.
    Battery should be O.K.
    When you put key into lock( without turning ), do you hear unlock steeringwheel ?( klicking noise?)
    If not check battery or -connections again.
    If yes check fuses.
    Ronald
    12MY RR TDV8 AB ipanama sand
    04 RR TD6 Vogue Silver for sale
    06 P 607 2.7 V6 TD
    12
    ok , no clicking of steering column , which fuses?, checked all the obvious ones in the glove box, steering column moves, seat moves, lights work, checked ecu fuses
    12
    ok , I checked every fuse in the glove box, and the rear compartment , all OK, battery voltage reads a healthy 12.65V, checked under both seats just in case there was a fuse link there , still no luck
    April 20th, 2006
    Houston, Texas USA
    521
    Did you lock and unlock using the remote? Maybe the security system is still on?
    April 2nd, 2007
    559
    Sounds like the key has lost programming with the car. I had bought an extra key for mine and had 2 out of the 3 reprogrammed to the car. The old key would lock and unlock the car but not start it.
    2011 Range Rover HSE LUX
    August 23rd, 2006
    27
    I had this problem with my 2003 RR. Try putting the key in the driver door lock and turning it 2-3 times. Somehow this would work for me. Road assistance told me to do this more than once.
    12
    Spoke to the dealer this morning , seems your conclusions of loss of program is correct, - i tried the door thing , but no luck- the bloody thing is now on the back of a transporter (at my cost of course!) to get everything put back into sync.at the dealer.
    thanks for all of your help
    12
    update, took dealers 2 days to diagnose the problem, apparently my ignition ecu has an internal short!!!, so tomorrow i get my Rangie back and the dealer gets $1600.00 - sometimes owning a Rangie really sucks!
  1. key won't turn in ignition.
    By scottuf in forum Range Rover Mark III / L322
    Last Post: September 3rd, 2011, 07:58 AM
  2. Ignition key won't fully turn
    By jimmyjam in forum Range Rover Classic
    Last Post: June 9th, 2011, 06:12 PM
  3. clicking noise when i turn ignition off
    By s1ggm in forum Range Rover Sport / L320
    Last Post: January 19th, 2011, 04:05 AM
  4. Key won't turn in ignition
    By 07RRBlackSC in forum Range Rover Mark III / L322
    Last Post: November 30th, 2010, 03:58 PM
  5. Key won't turn in ignition
    By zem in forum Range Rover Mark II / P38
    Last Post: April 26th, 2006, 08:27 PM
