My Radio/Nav Screen Froze - is this a common problem?
Results 1 to 6 of 6
Thread: My Radio/Nav Screen Froze - is this a common problem?
    March 20th, 2007
    205
    was driving last night - everything fine, turned the car off and then started it up again - and the LandRover screen was stuck frozen - the radio and CD functions worked - but the screen was frozen - after a while the LandRover screen went away and the normal radio screen appeared -- however, it too became frozen - it stayed on the same radio station and time, and computer function display even though i was changing stations -- after a while longer, the screen went blank/off - it wouldnt turn on (although the radio/CD continued to work) -- after leaving my car for a few hours, everything was back to normal
    so my questions are: a) is this a normal/common problem, and b) is it something that needs to get to the dealer asap?
    __________
    Russell
    Java Black HSE
    OGM M3 vert
    September 11th, 2006
    350
    start with checking the battery. If the truck is an 03-04 the voltage on the battery is crucial. A low voltage battery can still start the car, but can cause strange issues with the nav system
    December 26th, 2004
    Nashville, TN
    9
    Probably not a voltage issue but just one of those little quirks we come to know and love (ha). My 05 has done this a couple of times as well as the volume has increased by itself on occasion. The dealer always says not reproduceable and you laugh about it and move on.
    2005 HSE LUX
    March 20th, 2007
    205
    Quote Originally Posted by tblountman
    lol - that's what i figured. I'm not sure mine has speed sensitive volume, but my M3 does -- one day i was sitting at a red light, getting ready to make a red turn, and the volume went full blast - i nearly **** myself
    my windshield washer tank has a leak - so it's going back in this week - i will tell my S/A to take a look at the radio, but i am sure they wont be able to replicate the problem
    __________
    Russell
    Java Black HSE
    OGM M3 vert
    March 7th, 2005
    new york
    39
    Technology
    There is just to much technology in cars today. Its frightening and unnessasary.
    July 7th, 2006
    Boulder, CO
    19
    Re: My Radio/Nav Screen Froze - is this a common problem?
    Quote Originally Posted by miami m3
    So I have had that problem on two separate occasions. The first time it was resolved by some wire connections being adjusted by the dealer. The second time it was resolved by replacing the NAV cd as it was scratched. My screen had actually been freezing for months and I just assumed that the unit needed to be replaced. When I took it to the dealer though, they replaced the cd and it started working properly. What a relief as I was expecting to replaced the NAV controller.
    Rizz
    2004 Range Rover HSE
    2002 Lincoln LSV8
  1. Stolen brembo brake covers. Common problem?
    By tuckwoods in forum Range Rover Sport / L320
    Last Post: May 6th, 2011, 03:42 AM
  2. Radio LCD Screen
    By JeremyD in forum Range Rover Mark II / P38
    Last Post: November 5th, 2009, 11:32 PM
  3. Radio not working - not even displaying on screen
    By christophersaul in forum Range Rover Mark III / L322
    Last Post: September 9th, 2008, 01:44 PM
  4. Leak from transfer case (maybe) - is this a common problem?
    By kinko in forum Range Rover Mark II / P38
    Last Post: August 29th, 2007, 06:16 PM
  5. radio display screen light
    By richo ballina in forum Range Rover Mark II / P38
    Last Post: March 26th, 2006, 03:49 PM
