LWB with 22s or 21s - Page 2
Results 16 to 20 of 20
Thread: LWB with 22s or 21s
    December 23rd, 2016
    Seattle
    14
    Re: LWB with 22s or 21s
    Just wanted to update my finding on my rough and noisy ride with my 22' rims. I had purchased my 22' rim on eBay. I was nervous about the purchase but upon receiving them I had the dealer verify that it was OEM rims. When my RR arrived I had the dealer swap out my stock 21' rim for the new 22' rim. I took it home and found that the ride was rough and little noisy. Today I brought it back to the dealer to inspect and it turn out that the rim lucky is OEM but the tire that I had on them weren't. Ebay's seller put on some cheaper tires call the Nitto Extreme. Stupid me didn't check tire before buying the rims. I ask to test drive a RR with 22' rim on the dealership lot and boy there was a big different! The ride was a lot smoother with the Continental tires. Now I have to purchase the Stock tires which are Continetal CrossContact for $400 a piece. Lesson here is when something seem too good to be true most likely it is. At 40 I'm still trying to learn this lesson. lol
    August 26th, 2007
    8,245
    Nitto's are excellent tires, we run them exclusively on our Rovers. From the P38's, the DII to the MkIII. They ride and perform fantastic on them.
    Hopefully you dont go wasting another load of money on the OEM brand tires.
    '03 L322 HSE
    '04 DiscoII - wheeling rig
    December 23rd, 2016
    Seattle
    14
    [QUOTE=leftlanetruckin;1848250]Nitto's are excellent tires, we run them exclusively on our Rovers. From the P38's, the DII to the MkIII. They ride and perform fantastic on them.
    If you believe that my ride is rough isn't do to my Nitto tires, then do you have any suggestion for the ride being rough? I know this rough ride is not normal. The dealership drove it and agree that this is not normal. They had assured me that the rims are OEM. I even ask to test drive a RR with the same rim with the Continental tire and the ride is way smoother. Any suggestion would help.
    December 30th, 2008
    San Diego Ca
    77
    [QUOTE=apolloqa17;1848618]
    Quote Originally Posted by leftlanetruckin View Post
    What is the side wall size on both tires ?
    I have seen a lot of RR with say 285/35/22 so a 35 size side wall, but I would not go that small.
    I just changed from 255/55/19 to 285/40/22 on my L322, Im picky and I really can't tell much difference. I think Land Rover recently changed the 22 tire size from a 35 side wall to a 40. Just like most things in life there are many factors at play here, like.....
    - Tire Quality - Lots to read on this
    - Tire size - As talked about above size matters
    - Tire air pressure - Lowering it from say 45lbs to 40lbs or even 38lbs can make a big difference in noise and ride
    - Tire and Wheel weight - My stock set up was 77lbs, now I'm at 73lbs, lower rotational mass has lots of benefits
    Make sure you are not compairing apple to oranges as they say.
    I your case I would start off by checking the tire side wall size and your air pressure, Nitto Extremes are know to be noisy and ride ruff with higher air pressure.
    2006 Range Rover HSE - Zermatt Silver / Navy/Sand
    2011 Jaguar XJ - Polaris White / London Tan/Navy
    December 23rd, 2016
    Seattle
    14
    [QUOTE=karlc;1848970]
    Quote Originally Posted by apolloqa17 View Post
    Thank you Karl for your respond. The Nitto tires I have on there are 275/40R22 and the OEM Continental Tires that are suggested is the same. The pressure I currently have on the Nitto are 37 Psi for the front and 45 psi for the rear tire. I had ask the service guy if that was normal for the front and real tires to be different and he said that that was what RR suggested the tire PSI be. Should I ask them to lower the Psi? I am in kinda of a dilemma. I don't mind spending the money to get the Continental tires but service guy can't say for sure if it will improver my ride. If getting different tire won't improve my ride than what is wrong with the car? I know some may say that the ride is normal if you want bigger rim. Again, I had test drove a car on the lot with same rim with the Continental Tires and for sure there's a big different.
  1. No 22s on LWB RR?
    By onesixeight in forum Range Rover Mark IV / L405
    Last Post: March 29th, 2014, 09:10 AM
  2. New 22s for my 2013 RR
    By mjeagent in forum Range Rover Mark IV / L405
    Last Post: March 8th, 2014, 08:37 AM
  3. 22s with 35 or 40 sidewall
    By j0n1 in forum Range Rover Sport / L320
    Last Post: August 10th, 2011, 01:09 PM
  4. RRS ON 22s Pics
    By Bossman in forum Range Rover Sport / L320
    Last Post: May 1st, 2006, 09:39 PM
