Which Fuse for a Dash cam ?
Results 1 to 7 of 7
Thread: Which Fuse for a Dash cam ?
    August 25th, 2014
    England
    Fitting a dash cam tomorrow - want permanent 12v feed so it monitors when parked, and I'm taking the cable to the passenger fusebox, behind the glovebox.
    Anyone know which is the best fuse in that box to pick up a permanent 12v feed please?
    August 27th, 2014
    NYC
    214
    Re: Which Fuse for a Dash cam ?
    I don't know which fuse we tapped but make sure you use something like a power magic pro unless this is your daily driver
    22,909
    even if it is a daily driver you are asking for trouble having a drain 24 hours a day.You will have not only the drain from the camera system but the main systems in the car will most likely not be able to "go to sleep" which will add to the power draw.
    I've learned so much from my mistakes,
    I am thinking about making a few more.
    December 29th, 2013
    Windham, New Hampshire
    992
    Not sure if your kit requires the same method but someone just did something similar in a Sport. Might be worth reading/getting in touch: Radar Detector Install on Rear View Mirror+Power
    nevermind, I now realize you want the power to be permanent (probably not a great thing for the car), but I leave this here for future searches.
    August 25th, 2014
    England
    Going to use a smart power adaptor, which shuts down if battery voltage drops to a threshold level.
    so should be Ok.
    But which fuse position ?
    August 2nd, 2016
    Vancouver, BC
    7
    Anyone ever figure this out?
    The hardwire kits/power magic pro's these days manage power in a way that as richmond hall stated, shuts the camera off if the battery voltgage drops below a certain threshold. This threshold is something you can customize.
    I'm also looking to see if anyone can share which fuses they tapped.
    I've installed dashcams with the power management units in a few BMWs so I know which fuses to use based on the icon on the fuse map. I wonder if I can just pick the same icons on the RR Sport fuse map and go with that....hmmm...
    June 13th, 2012
    Chicago
    19
    Yes, fuse box behind glove box. Believe it was 52. Should be a yellow 20amp. Check fuse list in your manual. This one should be for accessory power socket in cubby box. That is where my dashcam is on. That one powers when you open door, ignition on, when you leave car with small delay which is perfect for dash cam. Also you can use fuse 60 which is purely ignition on off.
  1. Dash Cam Installation(hardwiring)
    By FrankXu in forum Range Rover Sport II / L494
    Last Post: Yesterday, 01:53 PM
  2. Dash CAM and TPMS Interference - where to mount?
    By rangerover08 in forum Range Rover Mark III / L322
    Last Post: September 10th, 2015, 11:11 AM
  3. Dash Cam
    By NYCRSS in forum Range Rover Sport II / L494
    Last Post: May 22nd, 2015, 11:43 AM
  4. Installing dash cam
    By Jarvis in forum Range Rover Sport / L320
    Last Post: April 21st, 2014, 08:53 AM
  5. Wiring up a dash cam
    By DaveCap in forum Range Rover Mark III / L322
    Last Post: December 3rd, 2013, 02:18 PM
