EAS Unlock P38 Can't do it!!!!!
Results 1 to 7 of 7
Thread: EAS Unlock P38 Can't do it!!!!!
    September 2nd, 2011
    11
    Hi All,
    I have the cable and software from RSWsolutions but can't get anything to talk to each other!!!!!!
    I get an error messafe stating "Comms Initialization Failed. configure your ports fron the EAS Tools dropdown menu"
    Can anybody help me "configure my ports" please? On my download there is no "Tools menu"
    Many thanks in advance
    October 8th, 2006
    United Kingdom
    80
    Re: EAS Unlock P38 Can't do it!!!!!
    Hi
    If you go to www.rswsolutions.com you will see videos and instructions for the EAS software. Also a link to download the EAS Suite software.
    I have not seen a version of the software without an EAS Tools click and drop down menu but I know the EAS SUITE version certainly has it.
    Good luck
    Range Rover 4.6 HSE Vogue 2000
    June 13th, 2006
    Kuala Lumpur
    1,847
    Hi
    In the left upper corner you see the pull down menu EAS Set up. Click on this and select COM. Now select COM1 and try again and if no success then COM2 and so on until the program responds.
    If you are using USB port, make sure your software for the converter cable is installed.
    Good luck
    Jos
    1995 RR 4.0 SE
    September 2nd, 2011
    11
    I think it's my USB adaptor.
    Because they are cheap I've ordered another in orderto eliminate it.
    Was worried that I had developed some form of EAS CPU failure that could not be re-set but was OK on Test-Book.
    Thanks forthe help. Once new USB adapter arrives I'll let you know what happens
    August 30th, 2010
    Trumbull CT
    62
    is the driver ok for usb adapter?
    Com listing in device manager doesnt mean thats your com.
    Mine shows 5 but eas software works on 4
    I suggest you try every com until you get a return value, then you r good to go
    ps
    Make sure your usb driver is working correctly
    06 Pontiac GTO
    99 Range Rover
    89 Ford Bronco II
    September 2nd, 2011
    11
    sorted!
    New USB to serial jobbie and I'm unlocked. Just need to learn how to make the most of the software now.
    Thanks for the support
    September 27th, 2006
    Paris, FRANCE
    2,490
    Hello,
    Would be helpfull if you put your location (Germany ? if i remember correctly ) in your avatar.
    Florent Houy
    http://www.rr-evolution.com
    1997 P38 4.6
    LPG
    SD L322 Rack adapted to P38
    DC5000 EAS Compressor
    Arnott Gen3
    32 inch BF KM2 tires
    Custom Mantec Snorkel
    RPI Sport Exhaust
    H4 Bixenons bulbs
  1. remote lock/unlock dead but key won't unlock car manully
    By olddog in forum Range Rover Mark III / L322
    Last Post: March 26th, 2010, 07:57 AM
  2. EAS Unlock for PDA
    By BigMack in forum Diagnostic Equipment
    Last Post: December 21st, 2009, 07:44 PM
  3. EAS unlock help
    By brian.kehoe in forum Range Rover Mark II / P38
    Last Post: March 1st, 2008, 01:40 PM
  4. EAS unlock using RTS pin on EAS itself (outside the car)
    By wpr in forum Diagnostic Equipment
    Last Post: February 10th, 2008, 03:14 AM
  5. TV Unlock
    By Mr.Range Rover in forum Range Rover Mark III / L322
    Last Post: December 5th, 2007, 03:36 PM
