Diagnostic Trouble Codes - Non Land Rover Specific
Closed Thread
Results 1 to 8 of 8
Thread: Diagnostic Trouble Codes - Non Land Rover Specific
    October 3rd, 2005
    Wellington, Somerset, UK
    4,647
    Diagnostic Trouble Codes (DTC's) or P-Codes:
    The following tables list the fault descriptions associated with particualar P-Codes, the list is not intended to be exhaustive, as additional P-Codes may be added at any time dependent on emissions systems employed, introduction of new components particular to a manufacturer or Engine Control Module specific codes.
    P-Codes beginning with the designation P-0xxx are Society of Automotive Engineers (SAE) defined codes and are intended to be generic to all vehicles and manufacturers worldwide. The DTC's were originally developed for OBD-II systems and are refered to as SAE J2012 standards.
    P-Codes beginning with the designation P-1xxx are manufacturer specific codes which may be associated with a particular Engine Control Module, component or system.
    This list only covers generic P-Codes from P-0100 up to P-0999. I'm trying to compile separate lists for ECM specific vehicles, such as GEMS.
    Emission Management (Air/Fuel) Fault Codes P0100-P0199
    P0100 Mass or Volume Air flow Circuit Malfunction
    P0101 Mass or Volume Air flow Circuit Range/Performance Problem; Mass Air Flow Sensor Signal Error Fault
    P0102 Mass or Volume Air Flow Circuit low Input; Mass Air Flow Sensor Low Out of Range Fault
    P0103 Mass or Volume Air flow Circuit High Input; Mass Air Flow Sensor High Out of Range Fault
    P0104 Mass or Volume Air flow Circuit Intermittent
    P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
    P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
    P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
    P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
    P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
    P0110 Intake Air Temperature Circuit Malfunction
    P0111 Intake Air Temperature Circuit Range/Performance Problem; Air Temperature Sensor Signal Error Fault
    P0112 Intake Air Temperature Circuit Low Input; Air Temperature Sensor Low Out of Range Fault
    P0113 Intake Air Temperature Circuit High Input; Air Temperature Sensor High Out of Range Fault
    P0114 Intake Air Temperature Circuit Intermittent
    P0115 Engine Coolant Temperature Circuit Malfunction
    P0116 Engine Coolant Temperature Circuit Range/Performance Problem; Engine Coolant Temperature Sensor Falling Temp Fault
    P0117 Engine Coolant Temperature Circuit Low Input; Engine Coolant Temperature Sensor Low Out of Range Fault
    P0118 Engine Coolant Temperature Circuit High Input; Engine Coolant Temperature Sensor High Out of Range Fault Short to Earth?
    P0119 Engine Coolant Temperature Circuit Intermittent
    P0120 Throttle Pedal Position Sensor/Switch A Circuit Malfunction
    P0121 Throttle/Pedal Position Sensor/Switch A Circuit Range/Performance Problem
    P0122 Throttle/Pedal Position Sensor/Switch A Circuit Low Input; Throttle Position Sensor Low Out of Range Fault Exceeds max threshold
    P0123 Throttle/Pedal Position Sensor/Switch A Circuit High Input; Throttle Position Sensor High Out of Range Fault
    P0124 Throttle/Pedal Position Sensor/Switch A Circuit Intermittent
    P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control; Engine Coolant Temp Sensor Warm Up Fault
    P0126 Insufficient Coolant Temperature for Stable Operation; Thermostat defective?
    P0130 Ox Sensor Circuit Malfunction (Bank 1 Sensor 1); Front HO2 sensor LH bank Stoichiometric ratio outside operating band
    P0131 Ox Sensor Circuit Low Voltage (Bank 1 Sensor 1); Front HO2 sensor LH bank short circuit to earth
    P0132 Ox Sensor Circuit High Voltage (Bank 1 Sensor 1); Front HO2 sensor LH bank short circuit to battery supply
    P0133 Ox Sensor Circuit Slow Response (Bank 1 Sensor 1); Front HO2 sensor aged period time too long/too short LH bank
    P0134 Ox Sensor Circuit No Activity Detected (Bank 1 Sensor 1); Front HO2 sensor LH bank open circuit
    P0135 Ox Sensor Heater Circuit Malfunction (Bank 1 Sensor 1); Upstream HO2 sensor heater LH bank short/open circuit
    P0136 Ox Sensor Circuit Malfunction (Bank 1 Sensor 2); Rear HO2 sensor LH bank stoichiomatric ratio outside operating band
    P0137 Ox Sensor Circuit Low Voltage (Bank 1 Sensor 2); Rear HO2 sensor LH bank short circuit to battery supply
    P0138 Ox Sensor Circuit High Voltage (Bank 1 Sensor 2); Rear HO2 sensor LH bank short circuit to earth
    P0139 Ox Sensor Circuit Slow Response (Bank 1 Sensor 2)
    P0140 Ox Sensor Circuit No Activity Detected (Bank 1 Sensor 2); Rear HO2 sensor LH bank open circuit
    P0141 Ox Sensor Heater Circuit Malfunction (Bank 1 Sensor 2); Downstream HO2 sensor heater LH bank Short/open circuit
    P0142 Ox Sensor Circuit Malfunction (Bank 1 Sensor 3)
    P0143 Ox Sensor Circuit Low Voltage (Bank 1 Sensor 3)
    P0144 Ox Sensor Circuit High Voltage (Bank 1 Sensor 3)
    P0145 Ox Sensor Circuit Slow Response (Bank 1 Sensor 3)
    P0146 Ox Sensor Circuit No Activity Detected (Bank 1 Sensor 3)
    P0147 Ox Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
    P0150 Ox Sensor Circuit Malfunction (Bank 2 Sensor 1); Front HO2 sensor RH bank stoichiometric ratio outside operating band
    P0151 Ox Sensor Circuit Low Voltage (Bank 2 Sensor 1); Front HO2 sensor RH bank short circuit to earth
    P0152 Ox Sensor Circuit High Voltage (Bank 2 Sensor 1); Front HO2 sensor RH bank short circuit to battery supply
    P0153 Ox Sensor Circuit Slow Response (Bank 2 Sensor 1); Front HO2 sensor aged period time too long/too short RH bank
    P0154 Ox Sensor Circuit No Activity Detected (Bank 2 Sensor 1); Front HO2 sensor RH bank open circuit
    P0155 Ox Sensor Heater Circuit Malfunction (Bank 2 Sensor 1); Upstream HO2 sensor heated RH bank short/open circuit
    P0156 Ox Sensor Circuit Malfunction (Bank 2 Sensor 2); Rear HO2 sensor RH bank stoichiometric ratio outside operating band
    P0157 Ox Sensor Circuit Low Voltage (Bank 2 Sensor 2); Rear HO2 sensor RH bank short circuit to battery supply
    P0158 Ox Sensor Circuit High Voltage (Bank 2 Sensor 2); Rear HO2 sensor short circuit to earth
    P0159 Ox Sensor Circuit Slow Response (Bank 2 Sensor 2)
    P0160 Ox Sensor Circuit No Activity Detected (Bank 2 Sensor 2); Rear HO2 sensor RH bank open circuit
    P0161 Ox Sensor Heater Circuit Malfunction (Bank 2 Sensor 2); Downstream HO2 sensor heater RH bank short/open circuit
    P0162 Ox Sensor Circuit Malfunction (Bank 2 Sensor 3)
    P0163 Ox Sensor Circuit Low Voltage (Bank 2 Sensor 3)
    P0164 Ox Sensor Circuit High Voltage (Bank 2 Sensor 3)
    P0165 Ox Sensor Circuit Slow Response (Bank 2 Sensor 3)
    P0166 Ox Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
    P0167 Ox Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
    P0170 Fuel Trim Malfunction (Bank 1); High leak rate LH bank
    P0171 System Too Lean (Bank 1); Multiplication injector adaptive fuelling lean limit exceeded LH bank
    P0172 System Too Rich (Bank 1); Multiplication injector adaptive fuelling rich limit exceeded LH bank
    P0173 Fuel Trim Malfunction (Bank 2); High leak rate RH bank
    P0174 System Too Lean (Bank 2); Multiplication injector adaptive fuelling lean limit exceeded RH bank
    P0175 System Too Rich (Bank 2); Multiplication injector adaptive fuelling rich limit exceeded RH bank
    P0176 Fuel Composition Sensor Circuit Malfunction
    P0177 Fuel Composition Sensor Circuit Range/Performance
    P0178 Fuel Composition Sensor Circuit Low Input
    P0179 Fuel Composition Sensor Circuit High Input
    P0180 Fuel Temperature Sensor A Circuit Malfunction
    P0181 Fuel Temperature Sensor A Circuit Performance; Fuel Temperature Sensor Signal Error Fault
    P0182 Fuel Temperature Sensor A Circuit low Input; Fuel Temperature Sensor Low Out of Range Fault
    P0183 Fuel Temperature Sensor A Circuit High Input; Fuel Temperature Sensor High Out of Range Fault
    P0184 Fuel Temperature Sensor A Circuit Intermittent
    P0185 Fuel Temperature Sensor B Circuit Malfunction
    P0186 Fuel Temperature Sensor B Circuit Range/Performance
    P0187 Fuel Temperature Sensor U Circuit Low Input
    P0188 Fuel Temperature Sensor B Circuit High Input
    P0189 Fuel Temperature Sensor B Circuit Intermittent
    P0190 Fuel Rail Pressure Sensor Circuit Malfunction
    P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
    P0192 Fuel Rail Pressure Sensor Circuit Low Input
    P0193 Fuel Rail Pressure Sensor Circuit High Input
    P0194 Fuel Rail Pressure Sensor Circuit Intermittent
    P0195 Engine Oil Temperature Sensor Malfunction
    P0196 Engine Oil Temperature Sensor Range/Performance
    P0197 Engine Oil Temperature Sensor Low
    P0198 Engine Oil Temperature Sensor High
    P0199 Engine Oil Temperature Sensor Intermittent
    October 3rd, 2005
    4,647
    Injector Circuit (Air/Fuel) Fault Codes P0200-P0299
    P0200 Injector Circuit Malfunction
    P0201 Injector Circuit Malfunction - Cylinder 1; Fuel injector cylinder 1 open circuit
    P0202 Injector Circuit Malfunction - Cylinder 2; Fuel injector cylinder 2 open circuit
    P0203 Injector Circuit Malfunction - Cylinder 3; Fuel injector cylinder 3 open circuit
    P0204 Injector Circuit Malfunction - Cylinder 4; Fuel injector cylinder 4 open circuit
    P0205 Injector Circuit Malfunction - Cylinder 5; Fuel injector cylinder 5 open circuit
    P0206 Injector Circuit Malfunction - Cylinder 6; Fuel injector cylinder 6 open circuit
    P0207 Injector Circuit Malfunction - Cylinder 7; Fuel injector cylinder 7 open circuit
    P0208 Injector Circuit Malfunction - Cylinder 8; Fuel injector cylinder 8 open circuit
    P0209 Injector Circuit Malfunction - Cylinder 9
    P0210 Injector Circuit Malfunction - Cylinder 10
    P0211 Injector Circuit Malfunction - Cylinder 11
    P0212 Injector Circuit Malfunction - Cylinder 12
    P0213 Cold Start Injector 1 Malfunction
    P0214 Cold Start Injector 2 Malfunction
    P0215 Engine Shutoff Solenoid Malfunction
    P0216 Injection Timing Control Circuit Malfunction
    P0217 Engine Overtemp Condition
    P0218 Transmission Over Temperature Condition
    P0219 Engine Over Speed Condition
    P0220 Throttle/Pedal Position Sensor/Switch B Circuit Malfunction
    P0221 Throttle/Pedal Position Sensor/Switch B Circuit Range/Performance Problem
    P0222 Throttle/Pedal Position Sensor/Switch B Circuit Low Input
    P0223 Throttle/Pedal Position Sensor/Switch B Circuit High Input
    P0224 Throttle/Pedal Position Sensor/Switch B Circuit Intermittent
    P0225 Throttle/Pedal Position Sensor/Switch C Circuit Malfunction
    P0226 Throttle/Pedal Position Sensor/Switch C Circuit Range/Performance Problem
    P0227 Throttle/Pedal Position Sensor/Switch C Circuit Low Input
    P0228 Throttle/Pedal Position Sensor/Switch C Circuit High Input
    P0229 Throttle/Pedal Position Sensor/Switch C Circuit Intermittent
    P0230 Fuel Pump Primary Circuit Malfunction
    P0231 Fuel Pump Secondary Circuit Low
    P0232 Fuel Pump Secondary Circuit High
    P0233 Fuel Pump Secondary Circuit Intermittent
    P0234 Turbocharger Overboost Condition
    P0235 Turbocharger Boost Sensor A Circuit Malfunction
    P0236 Turbocharger Boost Sensor A Circuit Range/Performance
    P0237 Turbocharger Boost Sensor A Circuit Low
    P0238 Turbocharger Boost Sensor A Circuit High
    P0239 Turbocharger Boost Sensor B Circuit Malfunction
    P0240 Turbocharger Boost Sensor B Circuit Range/Performance
    P0241 Turbocharger Boost Sensor B Circuit Low
    P0242 Turbocharger Boost Sensor B Circuit High
    P0243 Turbocharger Wastegate Solenoid A Malfunction
    P0244 Turbocharger Wastegate Solenoid A Range/Performance
    P0245 Turbocharger Wastegate Solenoid A low
    P0246 Turbocharger Wastegate Solenoid A High
    P0247 Turbocharger Wastegate Solenoid B Malfunction
    P0248 Turbocharger Wastegate Solenoid B Range/Performance
    P0249 Turbocharger Wastegate Solenoid B Low
    P0250 Turbocharger Wastegate Solenoid B High
    P0251 Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
    P0252 Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
    P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
    P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
    P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
    P0256 Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
    P0257 Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector)
    P0258 Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
    P0259 Injection lump Fuel Metering Control "B" High (Cam/Rotor/Injector)
    P0260 Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
    P0261 Cylinder 1 Injector Circuit Low; Injector 1 short circuit to earth
    P0262 Cylinder 1 Injector Circuit High; Injector 1 short circuit to battery supply
    P0263 Cylinder 1 Contribution/Balance Fault
    P0264 Cylinder 2 Injector Circuit Low; Injector 2 short circuit to earth
    P0265 Cylinder 2 Injector Circuit High; Injector 2 short circuit to battery supply
    P0266 Cylinder 2 Contribution/Balance Fault
    P0267 Cylinder 3 Injector Circuit Low; Injector 3 short circuit to earth
    P0268 Cylinder 3 Injector Circuit High; Injector 3 short circuit to battery supply
    P0269 Cylinder 3 Contribution/Balance Fault
    P0270 Cylinder 4 Injector Circuit Low; Injector 4 short circuit to earth
    P0271 Cylinder 4 Injector Circuit High; Injector 4 short circuit to battery supply
    P0272 Cylinder 4 Contribution/Balance Fault
    P0273 Cylinder 5 Injector Circuit Low; Injector 5 short circuit to earth
    P0274 Cylinder 5 Injector Circuit High; Injector 5 short circuit to battery supply
    P0275 Cylinder 5 Contribution/Balance Fault
    P0276 Cylinder 6 Injector Circuit Low; Injector 6 short circuit to earth
    P0277 Cylinder 6 Injector Circuit High; Injector 6 short circuit to battery supply
    P0278 Cylinder 6 Contribution/Balance Fault
    P0279 Cylinder 7 Injector Circuit Low; Injector 7 short circuit to earth
    P0280 Cylinder 7 Injector Circuit High; Injector 7 short circuit to battery supply
    P0281 Cylinder 7 Contribution/Balance Fault
    P0282 Cylinder 8 Injector Circuit Low; Injector 8 short circuit to earth
    P0283 Cylinder 8 Injector Circuit High; Injector 8 short circuit to battery supply
    P0284 Cylinder 8 Contribution/Balance Fault
    P0285 Cylinder 9 Injector Circuit Low
    P0286 Cylinder 9 Injector Circuit High
    P0287 Cylinder 9 Contribution/Balance Fault
    P0288 Cylinder 10 Injector Circuit Low
    P0289 Cylinder 10 Injector Circuit High
    P0290 Cylinder 10 Contribution/balance Fault
    P0291 Cylinder 11 Injector Circuit Low
    P0292 Cylinder 11 Injector Circuit High
    P0293 Cylinder 11 Contribution/balance Fault
    P0294 Cylinder 12 Injector Circuit Low
    P0295 Cylinder 12 Injector Circuit High
    P0296 Cylinder 12 Contribution/Balance Fault
    P0298 Engine Oil Over Temperature
    October 3rd, 2005
    4,647
    Ignition or misfire fault codes P0300-P0399
    P0300 Random/Multiple Cylinder Misfire Detected; Excess emissions/catalyst damaging level of misfire detected on more than one cylinder
    P0301 Cylinder 1 Misfire Detected; Fuel injector cylinder 1 excess emission/catalyst damaging level of misfire
    P0302 Cylinder 2 Misfire Detected; Fuel injector cylinder 2 excess emission/catalyst damaging level of misfire
    P0303 Cylinder 3 Misfire Detected; Fuel injector cylinder 3 excess emission/catalyst damaging level of misfire
    P0304 Cylinder 4 Misfire Detected; Fuel injector cylinder 4 excess emission/catalyst damaging level of misfire
    P0305 Cylinder 5 Misfire Detected; Fuel injector cylinder 5 excess emission/catalyst damaging level of misfire
    P0306 Cylinder 6 Misfire Detected; Fuel injector cylinder 6 excess emission/catalyst damaging level of misfire
    P0307 Cylinder 7 Misfire Detected; Fuel injector cylinder 7 excess emission/catalyst damaging level of misfire
    P0308 Cylinder 8 Misfire Detected; Fuel injector cylinder 8 excess emission/catalyst damaging level of misfire
    P0309 Cylinder 9 Misfire Detected
    P0310 Cylinder 10 Misfire Detected
    P0311 Cylinder 11 Misfire Detected
    P0312 Cylinder 12 Misfire Detected
    P0313 Misfire Detected with Low Fuel
    P0314 Single Cylinder Misfire (Cylinder not Specified)
    P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
    P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
    P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
    P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
    P0325 Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)
    P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
    P0327 Knock Sensor 1 Circuit low Input (Bank 1 or Single Sensor); Knock sensor LH bank signal smaller than threshold determined from ECM model above 2200 rev/min
    P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor); Knock sensor LH bank signal greater than threshold determined from ECM model above 2200 rev/min
    P0329 Knock Sensor 1 Circuit Input Intermittent (Bank 1 or Single Sensor)
    P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
    P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
    P0332 Knock Sensor 2 Circuit Low Input (Bank 2); Knock sensor RH bank signal smaller than threshold determined from ECM model above 2200 rev/min
    P0333 Knock Sensor 2 Circuit High Input (Bank 2); Knock sensor RH bank signal greater than threshold determined from ECM model above 2200 rev/min
    P0334 Knock Sensor 2 Circuit Input Intermittent (Bank 2)
    P0335 Crankshaft Position Sensor A Circuit Malfunction; CKP sensor reference mark outside search window with engine speed above 500 rev/min for 2 rev/min
    P0336 Crankshaft Position Sensor A Circuit Range/Performance; CKP sensor incorrect number of teeth detected 1 tooth between reference marks
    P0337 Crankshaft Position Sensor A Circuit Low Input
    P0338 Crankshaft Position Sensor A Circuit High Input
    P0339 Crankshaft Position Sensor A Circuit Intermittent
    P0340 Camshaft Position Sensor Circuit Malfunction; Open/short circuit to vehicle supply or earth
    P0341 Camshaft Position Sensor Circuit Range/Performance
    P0342 Camshaft Position Sensor Circuit Low Input
    P0343 Camshaft Position Sensor Circuit High Input
    P0344 Camshaft Position Sensor Circuit Intermittent
    P0350 Ignition Coil Primary/Secondary Circuit Malfunction
    P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
    P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
    P0353 Ignition Coil C Primary/Secondary Circuit Malfunction
    P0354 Ignition Coil D Primary/Secondary Circuit Malfunction
    P0355 Ignition Coil E Primary/Secondary Circuit Malfunction
    P0356 Ignition Coil F Primary/Secondary Circuit Malfunction
    P0357 Ignition Coil G Primary/Secondary Circuit Malfunction
    P0358 Ignition Coil H Primary/Secondary Circuit Malfunction
    P0359 Ignition Coil I Primary/Secondary Circuit Malfunction
    P0360 Ignition Coil J Primary/Secondary Circuit Malfunction
    P0361 Ignition Coil K Primary/Secondary Circuit Malfunction
    P0362 Ignition Coil L Primary/Secondary Circuit Malfunction
    P0370 Timing Reference High Resolution Signal A Malfunction
    P0371 Timing Reference High Resolution Signal A Too Many Pulses
    P0372 Timing Reference High Resolution Signal A Too Few Pulses
    P0373 Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
    P0374 Timing Reference High Resolution Signal A No Pulses
    P0375 Timing Reference High Resolution Signal B Malfunction
    P0376 Timing Reference High Resolution Signal B Too Many Pulses
    P0377 Timing Reference High Resolution Signal B Too Few Pulses
    P0378 Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
    P0379 Timing Reference High Resolution Signal B No Pulses
    P0380 Glow Plug/Heater Circuit "A" Malfunction
    P0381 Glow Plug/Heater Indicator Circuit Malfunction
    P0382 Glow Plug/Heater Circuit "B" Malfunction
    P0385 Crankshaft Position Sensor B Circuit Malfunction
    P0386 Crankshaft Position Sensor B Circuit Range/Performance
    P0387 Crankshaft Position Sensor B Circuit Low Input
    P0388 Crankshaft Position Sensor B Circuit High Input
    P0389 Crankshaft Position Sensor B Circuit Intermittent
    October 3rd, 2005
    4,647
    Emission Control Fault Codes P0400-P0499
    P0400 Exhaust Gas Recirculation Flow Malfunction
    P0401 Exhaust Gas Recirculation Flow Insufficient Detected
    P0402 Exhaust Gas Recirculation Flow Excessive Detected
    P0403 Exhaust Gas Recirculation Circuit Malfunction
    P0404 Exhaust Gas Recirculation Circuit Range/Performance
    P0405 Exhaust Gas Recirculation Sensor A Circuit Low
    P0406 Exhaust Gas Recirculation Sensor A Circuit High
    P0407 Exhaust Gas Recirculation Sensor B Circuit Low
    P0408 Exhaust Gas Recirculation Sensor B Circuit High
    P0410 Secondary Air Injection System Malfunction
    P0411 Secondary Air Injection System Incorrect Flow Detected
    P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction
    P0413 Secondary Air Injection System Switching Valve A Circuit Open
    P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
    P0415 Secondary Air Injection System Switching Valve B Circuit Malfunction
    P0416 Secondary Air Injection System Switching Valve B Circuit Open
    P0417 Secondary Air Injection System Switching Valve B Circuit Shorted
    P0418 Secondary Air Injection System Relay "A" circuit Malfunction
    P0419 Secondary Air Injection System Relay "B Circuit Malfunction
    P0420 Catalyst System Efficiency Below Threshold (Bank 1); Catalyst efficiency deteriorated Bank A
    P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
    P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
    P0423 Heated Catalyst Efficiency Below Threshold (Bank l)
    P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
    P0430 Catalyst System Efficiency Below Threshold (Bank 2); Catalyst efficiency deteriorated Bank B
    P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
    P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
    P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
    P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
    P0440 Evaporative Emission Control System Malfunction; Purge valve not sealing
    P0441 Evaporative Emission Control System Incorrect Purge flow
    P0442 Evaporative Emission Control System leak Detected (small leak); minor leak within system
    P0443 Evaporative Emission Control System Purge Control Valve circuit Malfunction; Purge valve short circuit to battery voltage
    P0444 Evaporative Emission Control System Purge Control Valve Circuit Open; Purge valve open circuit
    P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted; Purge valve short circuit to ground
    P0446 Evaporative Emission Control System Vent Control Circuit Malfunction; Purge canister vent valve functionality fault
    P0447 Evaporative Emission Control System Vent Control Circuit Open; Purge canister vent valve power stage fault
    P0448 Evaporative Emission Control System Vent Control Circuit Shorted; Purge canister vent valve power stage fault
    P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction; Purge canister vent valve power stage fault
    P0450 Evaporative Emission Control System Pressure Sensor Malfunction
    P0451 Evaporative Emission Control System Pressure Sensor Range/Performance; Fuel tank pressure signal stuck high within range
    P0452 Evaporative Emission Control System Pressure Sensor Low Input; Fuel tank pressure signal short circuit to battery voltage (out of range High)
    P0453 Evaporative Emission Control System Pressure Sensor High Input; DST signal short circuit to ground or open circuit (out of range Low)
    P0454 Evaporative Emission Control System Pressure Sensor Intermittent
    P0455 Evaporative Emission Control System Tank Detected (gross leak)
    P0460 Fuel Level Sensor Circuit Malfunction
    P0461 Fuel Level Sensor Circuit Range/Performance
    P0462 Fuel Level Sensor Circuit Low Input
    P0463 Fuel Level Sensor Circuit High Input
    P0464 Fuel Level Sensor Circuit Intermittent
    P0465 Purge Flow Sensor Circuit Malfunction
    P0466 Purge Flow Sensor Circuit Range/Performance
    P0467 Purge Flow Sensor Circuit Low Input
    P0468 Purge Flow Sensor Circuit High Input
    P0469 Purge Flow Sensor Circuit Intermittent
    P0470 Exhaust Pressure Sensor Malfunction
    P0471 Exhaust Pressure Sensor Range/Performance
    P0472 Exhaust Pressure Sensor Low
    P0473 Exhaust Pressure Sensor High
    P0474 Exhaust Pressure Sensor Intermittent
    P0475 Exhaust Pressure Control Valve Malfunction
    P0476 Exhaust Pressure Control Valve Range/Performance
    P0477 Exhaust Pressure Control Valve Low
    P0478 Exhaust Pressure Control Valve High
    P0479 Exhaust Pressure Control Valve Intermittent
    P0480 Cooling Fan 1 Control Circuit Malfunction
    P0481 Cooling Fan 2 Control Circuit Malfunction
    P0482 Cooling Fan 3 Control Circuit Malfunction
    P0483 Cooling Fan Rationality Check Malfunction
    P0484 Cooling Fan Circuit Over Current
    P0485 Cooling Fan Power/Ground Circuit Malfunction
    P0486 Exhaust Gas Recirculation Sensor "B" Circuit
    P0487 Exhaust Gas Recirculation Throttle Position Control Circuit
    P0488 Exhaust Gas Recirculation Throttle Position Control Range/Performance
    P0491 Secondary Air Injection System (Bank 1)
    P0492 Secondary Air Injection System (Bank 2)
    October 3rd, 2005
    4,647
    Idle Control Fault Codes PO500-PO578
    P0500 Vehicle Speed Sensor Malfunction; Vehicle speed signal open/short circuit
    P0501 Vehicle Speed Sensor Range/Performance; Vehicle speed signal implausible
    P0502 Vehicle Speed Sensor Circuit Low Input
    P0503 Vehicle Speed Sensor Intermittent/Erratic/High
    P0505 Idle Control System Malfunction
    P0506 Idle Control System RPM lower Than Expected
    P0507 Idle Control System RPM higher Than Expected
    P0510 Closed Throttle Position Switch Malfunction
    P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
    P0521 Engine Oil Pressure Sensor/Switch Range/Performance
    P0522 Engine Oil Pressure Sensor/Switch Low Voltage
    P0523 Engine Oil Pressure Sensor/Switch High Voltage
    P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
    P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
    P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
    P0533 A/C Refrigerant pressure Sensor Circuit High Input
    P0534 Air Conditioner Refrigerant Charge Loss
    P0550 Power Steering Pressure Sensor Circuit Malfunction
    P0551 Power Steering Pressure Sensor Circuit Range/Performance
    P0552 Power Steering Pressure Sensor Circuit Low Input
    P0553 Power Steering Pressure Sensor Circuit High Input
    P0554 Power Steering Pressure sensor Circuit Intermittent
    P0560 System Voltage Malfunction; Power supply system voltage error
    P0561 System Voltage Unstable
    P0562 System Voltage Low; Power supply system voltage low
    P0563 System Voltage High; Power supply system voltage high
    P0565 Cruise Control On Signal Malfunction
    P0566 Cruise Control Off Signal Malfunction
    P0567 Cruise Control Resume Signal Malfunction
    P0568 Cruise Control Set Signal Malfunction
    P0569 Cruise Control Coast Signal Malfunction
    P0570 Cruise Control Accel Signal Malfunction
    P0571 Cruise Control/Brake Switch A Circuit Malfunction
    P0572 Cruise Control/Brake Switch A Circuit Low
    P0573 Cruise Control/Brake Switch A Circuit High
    P0574 Cruise Control System - Vehicle Speed Too High
    P0575 Cruise Control Input Circuit
    P0576 Cruise Control Input Circuit Low
    P0577 Cruise Control Input Circuit High
    P0578 **through P0580 Reserved for Cruise Control Codes**
    October 3rd, 2005
    4,647
    Serial link fault codes PO600-PO665
    P0600 Serial Communication Link Malfunction; Controller Area Network (CAN) timed out
    P0601 Internal Control Module Memory Check Sum Error; CPU ROM fault
    P0602 Control Module Programming Error
    P0603 Internal Control Module Keep Alive Memory (KAM) Error; External RAM fault or fault memory errors implausible
    P0604 Internal Control Module Random Access Memory (RAM) Error; Internal RAM fault
    P0605 Internal Control Module Read Only Memory (ROM) Error (Module Identification Defined by SAE J1979)
    P0606 ECM/PCM Processor Fault; Knock ASIC test pulse or zero test error encountered (ECUs self test)
    P0608 Control Module VSS Output "A" Malfunction
    P0609 Control Module VSS Output "B" Malfunction
    P0610 Control Module VSS Output "B" Malfunction
    P0615 Starter Relay Circuit
    P0616 Starter Relay Circuit Low
    P0617 Starter Relay Circuit High
    P0618 Alternative Fuel Control Module KAM Error
    P0619 Alternative Fuel Control Module RAM/ROM Error
    P0620 Generator Control Circuit Malfunction
    P0621 Generator Lamp "L" Control Circuit Malfunction
    P0622 Generator Field "F" Control Circuit Malfunction
    P0623 Generator Lamp Control Circuit
    P0624 Fuel Cap Lamp Control Circuit
    P0630 VIN Not Programmed or Mismatch - ECM/PCM
    P0631 VIN Not Programmed or Mismatch - TCM
    P0635 Power Steering Control Circuit
    P0636 Power Steering Control Circuit Low
    P0637 Power Steering Control Circuit High
    P0638 Throttle Actuator Control Range/Performance (Bank 1)
    P0639 Throttle Actuator Control Range/Performance (Bank 2)
    P0640 Intake Air Heater Control Circuit
    P0645 A/C Clutch Relay Control Circuit
    P0646 A/C Clutch Relay Control Circuit Low
    P0647 A/C Clutch Relay Control Circuit High
    P0648 Immobilizer Lamp Control Circuit
    P0649 Speed Control Lamp Control Circuit
    P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
    P0654 Engine RPM Output Circuit Malfunction; Engine speed signal open circuit, short to ground or short to battery voltage
    P0655 Engine Hot Lamp Output Control Circuit Malfunction
    P0656 Fuel Level Output Circuit Malfunction
    P0660 Intake Manifold Tuning Valve Control Circuit (Bank 1)
    P0661 Intake Manifold Tuning Valve Control Circuit Low (Bank 1)
    P0662 Intake Manifold Tuning Valve Control Circuit High (Bank 1)
    P0663 Intake Manifold Tuning Valve Control Circuit (Bank 2)
    P0664 Intake Manifold Tuning Valve Control Circuit Low (Bank 2)
    P0665 Intake Manifold Tuning Valve Control Circuit High (Bank 2)
    October 3rd, 2005
    4,647
    Transmission control fault codes P0700-P0799
    P0700 Transmission Control System Malfunction
    P0701 Transmission Control System Range/Performance
    P0702 Transmission Control System Electrical
    P0703 Torque Converter/Brake Switch B Circuit Malfunction
    P0704 Clutch Switch Input Circuit Malfunction
    P0705 Transmission Range Sensor Circuit Malfunction (PRNDL Input)
    P0706 Transmission Range Sensor Circuit Range/Performance
    P0707 Transmission Range Sensor Circuit Low Input
    P0708 Transmission Range Sensor Circuit High Input
    P0709 Transmission Range Sensor Circuit Intermittent
    P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
    P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
    P0712 Transmission Fluid Temperature Sensor Circuit Low Input
    P0713 Transmission Fluid Temperature Sensor Circuit High Input
    P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
    P0715 Input/Turbine Speed Sensor Circuit Malfunction
    P0716 Input/Turbine Speed Sensor Circuit Range/Performance
    P0717 Input/Turbine Speed Sensor Circuit No Signal
    P0718 Input/Turbine Speed Sensor Circuit Intermittent
    P0719 Torque Converter/Brake Switch B Circuit Low
    P0720 Output Speed Sensor Circuit Malfunction
    P0721 Output Speed Sensor Circuit Range/Performance
    P0722 Output Speed Sensor Circuit No Signal
    P0723 Output Speed Sensor Circuit Intermittent
    P0724 Torque Converter/Brake Switch B Circuit High
    P0725 Engine Speed Input Circuit Malfunction
    P0726 Engine Speed Input Circuit Range/Performance
    P0727 Engine Speed Input Circuit No Signal
    P0728 Engine Speed Input Circuit Intermittent
    P0730 Incorrect Gear Ratio
    P0731 Gear 1 Incorrect Ratio
    P0732 Gear 2 Incorrect Ratio
    P0733 Gear 3 Incorrect Ratio
    P0734 Gear 4 Incorrect Ratio
    P0735 Gear 5 Incorrect Ratio
    P0736 Reverse Incorrect Ratio
    P0740 Torque Converter Clutch Circuit Malfunction
    P0741 Torque Converter Clutch Circuit Performance or Stuck Off
    P0742 Torque Converter Clutch Circuit Stuck On
    P0743 Torque Converter Clutch Circuit Electrical
    P0744 Torque Converter Clutch Circuit Intermittent
    P0745 Pressure Control Solenoid Malfunction
    P0746 Pressure Control Solenoid Performance or Stuck Off
    P0747 Pressure Control Solenoid Stuck On
    P0748 Pressure Control Solenoid Electrical
    P0749 Pressure Control Solenoid Intermittent
    P0750 Shift Solenoid A Malfunction
    P0751 Shift Solenoid A Performance or Stuck Off
    P0752 Shift Solenoid A Stuck On
    P0753 Shift Solenoid A Electrical
    P0754 Shift Solenoid A Intermittent
    P0755 Shift Solenoid B Malfunction
    P0756 Shift Solenoid B Performance or Stuck Off
    P0757 Shift Solenoid B Stuck On
    P0758 Shift Solenoid B Electrical
    P0759 Shift Solenoid B Intermittent
    P0760 Shift Solenoid C Malfunction
    P0761 Shift Solenoid C Performance or Stuck Off
    P0762 Shift Solenoid C Stuck On
    P0763 Shift Solenoid C Electrical
    P0764 Shift Solenoid C Intermittent
    P0765 Shift Solenoid D Malfunction
    P0766 Shift Solenoid D Performance or Stuck Off
    P0767 Shift Solenoid D Stuck On
    P0768 Shift Solenoid D Electrical
    P0769 Shift Solenoid D Intermittent
    P0770 Shift Solenoid E Malfunction
    P0771 Shift Solenoid E Performance or Stuck Off
    P0772 Shift Solenoid E Stuck On
    P0773 Shift Solenoid E Electrical
    P0774 Shift Solenoid E Intermittent
    P0775 Pressure Control Solenoid "B"
    P0776 Pressure Control Solenoid "B" Performance or Stuck off
    P0777 Pressure Control Solenoid "B" Stuck On
    P0778 Pressure Control Solenoid "B" Electrical
    P0779 Pressure Control Solenoid "B" Intermittent
    P0780 Shift Malfunction
    P0781 1-2 Shift Malfunction
    P0782 2-3 Shift Malfunction
    P0783 3-4 Shift Malfunction
    P0784 4-5 Shift Malfunction
    P0785 Shift/Timing Solenoid Malfunction
    P0786 Shift/Timing Solenoid Range/Performance
    P0787 Shift/Timing Solenoid low
    P0788 Shift/Timing Solenoid High
    P0789 Shift/Timing Solenoid Intermittent
    P0790 Normal/Performance Switch Circuit Malfunction
    P0791 Intermediate Shaft Speed Sensor Circuit
    P0792 Intermediate Shaft Speed Sensor Circuit Range/Performance
    P0793 Intermediate Shaft Speed Sensor Circuit No signal
    P0794 Intermediate Shaft Speed Sensor Circuit Intermittent
    P0795 Pressure Control Solenoid "C"
    P0796 Pressure Control Solenoid "C" Performance or Stuck off
    P0797 Pressure Control Solenoid "C" Stuck On
    P0798 Pressure Control Solenoid "C" Electrical
    P0799 Pressure Control Solenoid "C" Intermittent
    October 3rd, 2005
    4,647
    Transmission control fault codes PO800-PO849
    P0801 Reverse Inhibit Control Circuit Malfunction
    P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
    P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
    P0805 Clutch Position Sensor Circuit Malfunction
    P0806 Clutch Position Sensor Circuit Range/Performance Malfunction
    P0807 Clutch Position Sensor Circuit Low Malfunction
    P0808 Clutch Position Sensor Circuit High Malfunction
    P0809 Clutch Position Sensor Circuit Intermittent Malfunction
    P0810 Clutch Position Control Error
    P0811 Excessive Clutch Slippage
    P0812 Reverse Input Circuit
    P0813 Reverse Output Circuit
    P0814 Transmission Range Display Circuit
    P0815 Upshift Switch Circuit
    P0816 Downshift Switch Circuit
    P0817 Starter Disable Circuit
    P0818 Driveline Disconnect Switch Input Circuit
    P0820 Gear Lever X - Y Position Sensor Circuit
    P0821 Gear Lever X Position Circuit
    P0822 Gear Lever Y Position Circuit
    P0823 Gear Lever X Position Circuit Intermittent
    P0824 Gear Lever Y Position Circuit Intermittent
    P0825 Gear Lever Push - Pull Switch (Shift Anticipate)
    P0830 Clutch Pedal Switch "A" Circuit
    P0831 Clutch Pedal Switch "A" Circuit Low
    P0832 Clutch Pedal Switch "A" Circuit High
    P0833 Clutch Pedal Switch "B" Circuit
    P0834 Clutch Pedal Switch "B" Circuit Low
    P0835 Clutch Pedal Switch "B" Circuit High
    P0836 Four Wheel Drive (4WD) Switch Circuit
    P0837 Four Wheel Drive (4WD) Switch Circuit Range/Performance
    P0838 Four Wheel Drive (4WD) Switch Circuit Low
    P0839 Four Wheel Drive (4WD) Switch Circuit High
    P0840 Transmission Fluid Pressure Sensor/Switch "A" Circuit
    P0841 Transmission Fluid Pressure Sensor/Switch "A" Circuit Range/Performance
    P0842 Transmission Fluid Pressure Sensor/Switch "A" Circuit Low
    P0843 Transmission Fluid Pressure Sensor/Switch "A" Circuit High
    P0844 Transmission Fluid Pressure Sensor/Switch "A" Circuit Intermittent
    P0845 Transmission Fluid Pressure Sensor/Switch "B" Circuit
    P0846 Transmission Fluid Pressure Sensor/Switch "B" Circuit Range/Performance
    P0847 Transmission Fluid Pressure Sensor/Switch "B" Circuit Low
    P0848 Transmission Fluid Pressure Sensor/Switch "B" Circuit High
    P0849 Transmission Fluid Pressure Sensor/Switch "B" Circuit Intermittent
Closed Thread
  1. Pc based diagnostic land rover scanners
    By getlost4x4 in forum Diagnostic Equipment
    Last Post: November 13th, 2011, 11:38 AM
  2. New to Land Rover and already have error codes
    By chatas1 in forum Range Rover Sport / L320
    Last Post: November 6th, 2011, 06:30 PM
  3. Land Rover Discovery 2 - ABS Diagnostic Tool
    By Malafax_dand in forum Diagnostic Equipment
    Last Post: March 2nd, 2009, 01:54 PM
  4. Diagnostic Trouble Codes - GEMS Drive Cycles
    By Rich998a in forum Diagnostic Equipment
    Last Post: January 27th, 2009, 10:12 AM
  5. Diagnostic Trouble Codes - Land Rover GEMS p38 1994-1999
    Last Post: January 26th, 2009, 03:10 PM
