Scangauge II - Does it work with P38 V8 with no board comput - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 32 of 32
Thread: Scangauge II - Does it work with P38 V8 with no board comput
  1. #31
    August 26th, 2007
    8,584
    Re: Scangauge II - Does it work with P38 V8 with no board co
    To do what with exactly?
    Having the cable permanently strewn around to just look at numbers or clear codes, doesn't make much sense to me.
    If it's to clear codes, get a good reader. They can all view live data when it's needed, without the fancy packaging etc.
    '03 L322 HSE
    '04 DiscoII - wheeling rig
  3. #32
    October 25th, 2016
    Lingfield
    Was planning on drilling the ashtray and routing the cable behind the dash when I take the panels off to fix the hvac display and fit a USB socket instead of the lighter socket. Wanted it for viewing /clearing codes, monitoring voltage but think I might use a bluetooth OBD2 key I've just been given instead. Thought I'd ask on here in case anyone else had permenantly mounted one somewhere on the dash.
  1. Paint Pens... do they work? work well?
    By 05RR in forum Range Rover Mark III / L322
    Last Post: May 11th, 2011, 01:33 PM
  2. Hello Board
    By JtasticII in forum Range Rover Sport / L320
    Last Post: March 16th, 2009, 12:15 PM
  3. Scangauge/Troubleshooting
    By ghind in forum Diagnostic Equipment
    Last Post: February 5th, 2009, 03:01 PM
  4. new to the board ALSO
    By bluerange in forum Range Rover Sport / L320
    Last Post: May 23rd, 2006, 12:15 PM
  5. A/C and Heat: TO WORK OR NOT TO WORK? HELP NEEDED!
    By Bigbeardbiii in forum Range Rover Mark II / P38
    Last Post: April 17th, 2006, 06:50 PM
